Starting a engine after a lay up
- agentpineapple
Re: Starting a engine after a lay up
Nice one lloydie, sounds a lot stronger than the old lump....
Nice one Lloydie
that does sound very good
Now that's what I call a top birthday pressie, well done Lloydie, sounds good
Obviously you have it started now but there should have been no worries anyway with it standing without oil, there would still have been plenty of oil on all the internal components. when an engine is new it's more dry than one that's been drained, they lubricate bearings and bearing surfaces etc which on yours will be well lubed anyway.
Such a relief when it started not just the engine but all the bits have been changed - engine and loom so only the carbs are the same of last years bike .
I did have a huge smile when it fired up and I still have it ! Or is that because Virt had just left
Almost sounds as good as mine
glad its up and running. Have to make sure you get some miles on it next year
lloydie wrote:Such a relief when it started not just the engine but all the bits have been changed - engine and loom so only the carbs are the same of last years bike .
Well done bud sounds good and I'm presuming this ones not using more oil than fuel
It better not as that's why I brought it .Gazfirestormowner wrote:Well done bud sounds good and I'm presuming this ones not using more oil than fuel
I'm told it don't use any oil and the clutch is a non jumper :-)
Good work lloydie, but shouldn't you be out drinking by now?
Well it was when I run it.lloydie wrote:It better not as that's why I brought it .Gazfirestormowner wrote:Well done bud sounds good and I'm presuming this ones not using more oil than fuel
Never took it over 5k honest Guv & it had 3 previous lady owner's & two of them were vicar's...
Staying in and drinking lots as I'm a tight git and won't pay taxis besides if I go out I'd end up in Essex on a booty call (Jamie's mum) :-)AMCQ46 wrote:Good work lloydie, but shouldn't you be out drinking by now?
Staying in and drinking lots as I'm a tight git and won't pay taxis besides if I go out I'd end up in Essex on a booty call (Jamie's mum) :-)[/quote]
Sounds worth the taxi fare to me
A brand new engine wont be sitting around long before it gets oil, run and tested, and they are pre lubricated by parts suppliers.popkat wrote:Obviously you have it started now but there should have been no worries anyway with it standing without oil, there would still have been plenty of oil on all the internal components. when an engine is new it's more dry than one that's been drained, they lubricate bearings and bearing surfaces etc which on yours will be well lubed anyway.
