CCT Problem Solved (100% guaranteed)
- Fireman on a Storm
CCT
I am a new member and don`t know how long this subject has been running. The spring in the CCT unit on the front cylinder of my Firestorm broke a few weeks ago on the way back from Brands and the cam chain jumped the sprocket. I was very lucky and stopped befor it could cause serious damage. I now worry when ever I am out in case it happens again. Would be delighted if someone could come up with a solution to this problem. Honda don`t think there is one!
busydoingnothing
- Rollingalong
jono and Brian .
Go the http://www.aperaceparts.com or to the direct link here .
http://www.cbrzone.com/sprockets.html
They ship Internationaly
- TAFFTHEMAGICDRAGON
- Pete.L
Hi Taff
if it's not wrattling don't worry. Some have gone with less than 500 miles on the clock others have done 30,000 miles without a hitch.
My first one went at 18,000 and the replacement went 7,000 after that. Now 5,000 miles later the other one (which hasn't been changed from new) is starting to get a bit noisey when cold.
The main thing is as soon as you think you hear it change it. Then you can't go too far wrong
cct
Your suggestion Pete.L is fine if you are a couple of miles from home, but if you happen to be 70 miles from home and the chain jumps a sprocket without warning, and you have to wait hours to get the bike and yourself home, it`s not such a good idea. The problem needs solving.
I have had a look at the "aperaceparts" site suggested by "rollingalong" and seems that this may be an answer to this problem. I understand that this is a solution adopted in racing circles in many types of engine. I would be interested to hear other members views on this particular solution especially if they have used them themselves.
busydoingnothing
- Pete.L
Brainwnich said
normally you get a bit of warning but sometime life is unfair unless you have a crystal ball and know what you're doing
Then he said
And then he said
And I've just ordered a pair but there's a 2 week back order delay at the mo so I'll let you know when I get them
Well then you're buggardbut if you happen to be 70 miles from home and the chain jumps a sprocket without warning
Then he said
Don't hold your breath waiting on Honda. Their cam chain tensioners have been wrattling since the seventies and they haven't fixed em yet.The problem needs solving.
And then he said
Max also has had them fitted. He's just reported in 3000 miles so far and no problems.have had a look at the "aperaceparts" site suggested by "rollingalong" and seems that this may be an answer to this problem.
- Galaxieman
- Contact:
- Pete.L
Hi Curly, Galaxieman.
Ape tensioners just arrived today(so much for the two/three week dalay ) So I'm not complaining.
According to the instuctions (sticky label on rear of packaging) to correctly set the tension, remove the cam cover,push down on the chain between the cams and screw in the tensioner untill the is between 1/4 to 3/8" deflection in the chain.... Abridged version.
It doesn't say how often to adjust but if max has done 3000miles and it's not needed yet thats good enough for me.
As for removing the cam covers everytime they need adjusting I think I might go back to te old way and do it by ear after checking it a couple of times first
- roadrun_fr
