Hello From India
- Tam Cunningham
- Location: Perth, Scotland. thomaspcunningham@btinternet.com
Re: Hello From India
Welcome, get some pictures posted
Hello, World's Fastest Indian Firestorm- welcome!
Coming to the next camping weekend?
Welcome aboard
- chris vtr virgin
Welcome to the madhoose
Great bunch on here plenty of interesting reading about the storm
Some twins have all the fun !!!!
thank you all for the warm welcome.
myself own a 66 royal enfield, so no playing against those boys
having some issues with my picasa and unable to upload a pic
Now that's a turnaround. Someone from India asking for computer advice from us!!!
Looks nice mate, for a yellow one! Get those cct's sorted.
- agentpineapple
welkom,and that is a very nice bike
these CCT's are but mystery for me still, have to bit understand the use of manual CCT's and what is the issue with existing CCT'sKev L wrote:Looks nice mate, for a yellow one! Get those cct's sorted.
Basically the front one is likely to fail (corrosion on the spring due to flawed oil supply) this will result in a slack timing chain, jumped sprocket, valve into piston interface and a lot of expense/heartache.
Have a search through the workshop section on here for instruction on how to either replace with manuals or do a mod which prevents damage if the spring fails, called the "stopper mod".
Just do one or the other I would hate to read you have suffered a failure through lack of preventative maintenance.
Good luck.
Good luck.
thanks mate for the short and crisp info.Kev L wrote:Basically the front one is likely to fail (corrosion on the spring due to flawed oil supply) this will result in a slack timing chain, jumped sprocket, valve into piston interface and a lot of expense/heartache.
Good luck.
what was the difference between restricted and non-restricted VTR, how many BHP was the difference.
what is the actual BHP number for a 97 VTr, am getting different numbers on google
How many horses would go up after upgrading the exhaust and filters ?
Varies from country to country whether there is restriction or not.what was the difference between restricted and non-restricted VTR, how many BHP was the difference.
Same as above really and to add to that every bike will be slightly different. You looking to get between 100 and 110bhp depending on the dyno.what is the actual BHP number for a 97 VTr, am getting different numbers on google
It's not the horses you want to worry about...it's the cows in the road.How many horses would go up after upgrading the exhaust and filters
thank you carlcybercarl wrote:Varies from country to country whether there is restriction or not.what was the difference between restricted and non-restricted VTR, how many BHP was the difference.
another confusion i had was the decal in the tank and in the side panels.
pre 2000 model's had firestorm decal on the tank and post 2000 had over the panels, but mine has none anywhere
