some new goodies
Jscobey
Re: some new goodies
Post by Jscobey »
cybercarl wrote: I would like some mori pistons as they are slighter less compression and IIRC I think you can get away with running lower octane fuel (standard pump gas) with them. But as they are getting harder to source and usually a lot more expensive I will most likely end up with JE's. Or maybe I will skim the heads with standard pistons and play with cams instead. Or oversize standards and skimming the heads, now there's a thought.
i found some Moriwaki pistons. the compression is 10.8:1 so yes it is less. more along the lines of the RC51's compression. but if i bought them i wouldnt even have 20 bucks left over out of $1000. the JE's were around $250 delivered to my door. t
