which coolant to use.
Re: which coolant to use.
lumpyv wrote:interesting and informative thread this. :thumbup:
what is the volume of liquid required to fill a system??
Something like 3ltrs but I'd have to look it up to be sure...
Quick look at the PDF manual later...
SPECIFICATIONS
ITEM SPECIFICATIONS
Coolant capacity Radiotor and engine 2.9l~13.1 US L2.6 1m I)
Reserv tank 0.71l AIO. 188US ~ I 0.1581m al
RlIriilltor ca rel ief 'essul"l!
Thermostot Beagins to open
Full 0 en
Valve lift
108 137 kPII (1.1 1.4 kol/cm' , 16 20 psi)
73 77 'C (163 171°FI
90 'C 194 OF)
8 mm 10_3 in) minimum
Recommended antifreeze Pro Honda HP coolant or an eqUlvlI l ~ n l high qUllhty ethylene
glycol antifreeze containin silicate-free corrosion inhibitors.
rollingthunderx2
Post by rollingthunderx2 »
BBISHOPTM said on Adventureriders.
This is just an informative post regarding proper coolants to use in Honda scooters (and motorcycles), and similarly designed engines;
DO NOT use standard "Green" automotive coolant. I found this out accidentally (after actually using the right stuff). I found an old post on a Goldwing forum mentioning the use of off-the-shelf coolant, appaently, most coolants contain silicates; this is good for an automotive cooling system, as it provides the abrasive properties needed to keep coolant passages clear, but it DESTROYS the water-lubricated pump seals in motorcycle engines! You CAN use most long-life "universal" coolants that specifically state "no silicates" on the label, or just buy the factory stuff
So the main thing is just use Silicate free "antifreeze"
