newbie
Stormin Ben
Post by Stormin Ben »
VTR1000KAZ wrote:Although it doesn't feel like it all the time.....but sometimes its as if the forks are loose/rocking back and forth.......like I said tho...it doesn't feel like this all the time.....mainly on braking gently. Any other ideas???
Had this on my old ZZR, turned out to be the brake disk bobbins were not the right size!!
When you put the brakes on they 'clunked' round slightly before biting
Other thoughts,
The old favorite steering head bearings or possibly worn fork bushes?
If you raise the front off the ground (block under the engine is favourite) see if there's any front to back movement in the forks
Or wheel bearing
As above but grip the wheel at top and bottom and wiggle it. Any movement and either the bearings are going or the other half didn't tighten the spindle up last time he was tinkering (you haven't just taken out a whopping life insurance policy have you? :lol: )
Druid wrote:My WP was also sprung to match my weight (and middle age spread ) - maybe it depends who supplies the shock?
Druid, what I was trying to say (badly!!) was that even when they are 'sprung to match your weight' the weight of spring they use is usually still too firm.
Ben
logan7
Post by logan7 »
My "art cans" from busters just arived i now have a pair of microns much better imo so i am very happy :D .Roll on the weekend so i can get them fitted :twisted:
Kaz wrote
Although it doesn't feel like it all the time.....but sometimes its as if the forks are loose/rocking back and forth.......like I said tho...it doesn't feel like this all the time.....mainly on braking gently. Any other ideas???[Quote]
Hi Kaz,
It could be anything really from a sticking piston in the brake calipiers to worn steering head bearings. Did you ask your other half if he noticed it as well? If it were me i'd get it checked out if the both of you can not find the problem, just incase of any potential danger, it may be nothing serious at all!
cheers Chris.
