Cam Chain(?) noise
Re: Cam Chain(?) noise
Ahhh! There's someone in Oz (or NZ?) that also handles Mark Krieger's CCTs - I can't recall their details but try asking Mark directly > http://www.clems-garage.com/CCT/
paulp3333
Post by paulp3333 »
Just checked with Mark and he doesn't have a distributor in Australia any more.
adewhitmarsh
Post by adewhitmarsh »
I can supply manual ccts at a very competitive price & high quality ,find details on forum or pm me.
Shauned71
Post by Shauned71 »
Welcome to the forums. If you want to go another route and If by chance you are on facebook look for a guy named Jay Morrison. He has a yellow storm in his profile photo... He is in Melbourne and can supply krieger ccts.
paulp3333 wrote:That makes sense Chris.
But it only makes the noise while holding steady revs between 2 and 3 thousand revs. When backing off or accelerating everything is fine.
In which case I didn't think that's your problem. The noise I described due to a weak spring (sticking plunger) could be heard on the over-run, as in changing down and slowing down for a T junction, not on acceleration,
redpig
Post by redpig »
Let us know how it pans out Paul?
ook
Not ccts,but they should be done asap.
You say you've adjusted the drive chain. The. Adjustment on these is tricky and is best done two handed, get someone if a similar weight to you I.e. not a child, sit in the bike while you adjust the chain on a paddock stand.
If you do it with no-one on its easy to have the chain wrongly adjusted.
redpig
Post by redpig »
When the chains a bit stretched it tends to slap if your too high gear and low rev
ook
