Page 2 of 2
Re: Cam Chain(?) noise
Posted: Thu Feb 25, 2016 3:30 pm
by Wicky
Ahhh! There's someone in Oz (or NZ?) that also handles Mark Krieger's CCTs - I can't recall their details but try asking Mark directly >
http://www.clems-garage.com/CCT/
Posted: Thu Feb 25, 2016 4:01 pm
by paulp3333
Just checked with Mark and he doesn't have a distributor in Australia any more.
Posted: Thu Feb 25, 2016 5:37 pm
by adewhitmarsh
I can supply manual ccts at a very competitive price & high quality ,find details on forum or pm me.
Posted: Fri Feb 26, 2016 2:59 am
by Shauned71
Welcome to the forums. If you want to go another route and If by chance you are on facebook look for a guy named Jay Morrison. He has a yellow storm in his profile photo... He is in Melbourne and can supply krieger ccts.
Posted: Fri Feb 26, 2016 9:48 am
by sirch345
paulp3333 wrote:That makes sense Chris.
But it only makes the noise while holding steady revs between 2 and 3 thousand revs. When backing off or accelerating everything is fine.
In which case I didn't think that's your problem. The noise I described due to a weak spring (sticking plunger) could be heard on the over-run, as in changing down and slowing down for a T junction, not on acceleration,
Posted: Fri Mar 25, 2016 10:39 pm
by redpig
Let us know how it pans out Paul?
Posted: Sat Mar 26, 2016 9:43 am
by tony.mon
Not ccts,but they should be done asap.
You say you've adjusted the drive chain. The. Adjustment on these is tricky and is best done two handed, get someone if a similar weight to you I.e. not a child, sit in the bike while you adjust the chain on a paddock stand.
If you do it with no-one on its easy to have the chain wrongly adjusted.
Posted: Sat Mar 26, 2016 10:36 am
by redpig
When the chains a bit stretched it tends to slap if your too high gear and low rev
