Bike running rich & jerky at low rpm
Re: Bike running rich & jerky at low rpm
you mite find it as easy and cheap to pick up a set of secondhand carbs ?
Stephan
Post by Stephan »
dkj1000 wrote: Mon Mar 19, 2018 7:15 am Hi Stephan,
thanks for your advice, but as far as I know those settings are for "48" pilot jets which are larger than my "45's therefore when you have "45's" they have to be screwed out further.
I really need someone to advise if they know how to remove worn needle jets (guides) or where to buy them from please
I used this setting for 45, 48, 50 jets, and in std and modified stage 1 engine. I don´t say it is the best setting you can achieve, but as a starting point, it is working everywhere well enough in my experience.
dkj1000
Post by dkj1000 »
Finally got my VTR sorted :D
I ended up buying a second hand pair of carburetors (they were a lot cheaper than I thought they would be) which had good needle jets, swapped them over and cured the shitty low rpm running. I'm pretty happy had been working on it since early January!
I do plan to try and repair my original carbs by working out how to remove the worn needle jets and getting some new ones made.....
good new at least you are rolling again :thumbup:
