Speedo weirdness
Re: Speedo weirdness
jchesshyre wrote: Tue Sep 10, 2019 10:59 pm Update: turns out it was the speedo sensor.
Glad you found the culprit in the end, well done :thumbup:
nigelrb
Post by nigelrb »
I've just tapped into this rather than start a new thread.
Some will remember my posts of exceeding 180 miles on a tank of fuel. :roll:
My naive mind snapped to attention when some suggested sprockets had been changed. I finally checked the front and it's 16, so I am all stock at 16/41. Symptoms are the speed reads higher and miles tick over as quick as kilometres. I'm figuring I also have the speed sensor problem.
Nothing erratic in the reading, and it really doesn't bother me, EXCEPT it will make my bike a higher mileage than it actually is, so I must repair post haste. Thanks to this thread I'd best check battery terminals first. Could save me 30-plus quid!!
Any chance your bike was a European Grey import and it's only had the clock face changed to make it look like a GB bike?
Or, don't know if the miles are calculated in the ECU but if they are could it have been changed to an Euro one if the bike is and original brit one.
I thought the speed sensor normally went erratic or just quit when it went faulty. I haven't heard of one with your symptoms before????
Most odd :wtf:
Has it had a Speedo healer fitted and not calibrated properly?
Or a km clock with an overlay stuck on?
nigelrb
Post by nigelrb »
Thanks for your input Pete and Tony.
V5 has it as first reg in UK as 22/5/98, so I suspect it's not an import. I haven't poked around for a speedo healer specifically, but last time seat was off, I think I would have noted if there was something that looked non-original. It almost seems as if the relationship of the odometer is out of sync with the speedo, insomuch as the miles turn over at a higher ration of error than does the speed reading.
I was actually wondering about taking the cheap way out and just putting a 15T front sprocket on to negate the climbing mileage.
There is no overlay on the speedo. Pic below. The red 30 mph was a stick on by the previous fuddy-duddy owner 8O .
nigelrb wrote: Sun Jul 12, 2020 2:23 pm Thanks for your input Pete and Tony.
Well the clock face is not standard, so maybe they are KM clocks & the face has been replaced...
Std UK clocks the speedo is black...
Best bet is to try a different set of clocks & see what happens...
UK Standard clocks
Continental clocks
nigelrb
Post by nigelrb »
Thanks Mac and Wicky.
So I have an inbred clock :eek2 . I'll never be able to find out about that cos the bike came to me with nothing but 2 MoTs.
Makes me wonder now if it had been converted for someone maybe living in the Euro region for a while - hence the dual mph/kmh - and there is now a readout conflict. As previously written, I had felt as if the odometer was turning over in kilometres, but I think (in my limited Storm experience) these models don't have a conversion via the dash reset button.
New clocks might be the best solution. Is the mileage stored in the odometer or the ECU?
nigelrb
Post by nigelrb »
Pete.L wrote: Sun Jul 12, 2020 8:21 am Any chance your bike was a European Grey import and it's only had the clock face changed to make it look like a GB bike? . . .
You're on to something, Pete.
On re-reading the V5, the front says: 'Declared new in GB by independent importer.' (Still first regd in UK on 22/5/98, according to DVLA)
So it seems something has been botched - possibly over the life of the bike, BUT it's had 8 previous owners so I'm surprised no one has rectified this, OR none of them had a clue or couldn't be bothered.
Not the first case of a speedo to go spontaneously continental
> speedo problem > http://www.vtr1000.org/phpBB3/viewtopic ... 2c981533c5
Speedo weirdness
Interesting.
I wish I knew where info was held. ECU or clocks? Has anyone got a spare set you could swap out temporarily?
You don’t have to worry about the MOT they will just note a chang of clocks and list the original miles and the start miles of the new clocks
I suspect the clocks , Like Tony suggested. Probably had a little glitch
The good news is, your bike has less miles on it than you thought.
nigelrb
Post by nigelrb »
tony.mon wrote: Mon Jul 13, 2020 1:45 pm The good news is, your bike has less miles on it than you thought.
True Tony, but the downside might be convincing a prospective purchaser of that if/when the time comes to sell it.
No plans to do so of course. I might just leave it in my Will to an owner of a yellow Storm. Second thoughts, I won't - they'd probably repaint it yellow!! :lol:
lazy way, junk the clocks and get a uk set close as possible to the miles on the bike :thumbup:
True. As long as they're a little more than the milage at the last mot, you're good to go.
