Page 2 of 2
Posted: Wed May 31, 2006 9:15 am
by sirch345
Welcome aboard Big Stu
Cutting out at high rev's then picking up again at lower rev's does sound like a fuel problem to me, rather than an electrical problem, but unfortunately fuel and electrical problems often give very similar symptoms.
How many miles has it done and when was it last serviced, plugs and air filter etc
Posted: Wed May 31, 2006 10:58 am
by Big Stu
Hi Chris,
I have only had the bike 2 months and it was serviced before i picked it up. i am problably going to completely numb, but the speedo has a mind of its own and when the fuel reserve light is on and the indicators are used, the reserve light also flashes, could everything be related to the rectifier being knackered.
Posted: Thu Jun 01, 2006 10:08 am
by sirch345
Big Stu wrote:Hi Chris,
A good point Stu, best to check the voltage at the battery terminals first with a multi meter if you have one, if not perhaps you can borrow one, check first before starting the engine, should be 12volts, then with the engine running showing charging should be around 14volts and drop back to around 13volts when you switch on the headlight
HTH
Posted: Thu Jun 01, 2006 4:07 pm
by Big Stu
Thanks for the advice Chris, I will do the test and post the result.
Stu
Posted: Thu Jun 01, 2006 5:06 pm
by Kitch
yay! more Manchester people...
welcome aboard
Posted: Thu Jun 01, 2006 11:57 pm
by Big Stu
Thanks for the welcome fella.
I ve just bought a set of viper cans off ebay i hope they p*""* of the rest of the street. Stu
Posted: Sat Jun 03, 2006 8:04 pm
by doggit
stu, speaking of viper cans reminds me i must blow dry my hair
see ya on thursday for our razz around
and we can double the noise level
carl
Posted: Sat Jun 03, 2006 9:55 pm
by Big Stu
which hair mate, coz you only got the two left. The vipers sould great.
maybe a little too loud, see you wed and we are still on for thurs, stu
