craigybaby wrote:
It's got progressively worse so I think it's a consumable that's to blame. It was lovely and smooth when I took it out on test.
Does any one know roughly how much sprockets and chain are going to cost me?
I'd plump for the chain in this instance
Any tight spot etc is gonna be felt as vibration so pop it on a paddock stand and rotate the wheel BY HAND
Check the free play in the chain at frequent regular intervals (push up in the middle of the lower chain run and measure the amount of movement)
You'll probably find one or two points where the movement is significantly more than the rest of the chain
NBMake sure the adjustment at these tight spots is correct. There's no good having the chain adjusted right at a normal point if its tight as a drum on the tight spot
Also make sure it is nice and clean and well lubed
Next, on the rear sprocket, see how much off the sprocket you can pull the chain (from the 9 o'clock position as you look at the sprocket)
If its any more than the tiniest amount then the chain/ sprockets are shot
Steve from Paddockstand is probably your man to talk to WRT chain & sprockets (he gets B&C kit but at cheaper prices, I've used him myself a few times and been impressed with the service)
WRT carb balancing, its worth getting that done regularly anyway coz it feels sooo much smoother once they're right
