S the W!
Good one! Thanks for that. I think that if you look at the shadow cast by the machine you CAN see he was putting some daylight under the front wheel albeit not a lot.
Cheers, Chris (ex Canterbury!)
I know the motorcyclist is going over the speed limit but...
- Squiffythewombat
- Contact:
No worries, (future refrence, use the "PRT SC" button on your keyboard, press it when you want the freezeframe, then goto your favourite image program and press CTRL and V at the same time.
Personally i think he was just accerating quickly, if hes fat the front will lighten more so!
Canterbury? really..where abouts? (im actually in ash)
Squiffy_The_Wombat
- LotusSevenMan
- Squiffythewombat
- Contact:
Classic case of SITDYCSTBC.
Something I stick rigidly to since my big crash...
Still stumped? Stop In The Distance You Can See To Be Clear.
If you can't, then anything you hit is your fault 99.9% of the time.
Also worth a bit of EORUTDSS.
(Expect Other Road Users To Do Stupid sh1t)
