Using the same heatsink paste as we fit to all our Xeon & Opteron processor helped my "New" standard reg transfer more heat to the frame.
A gentle run down with v fine emery, a v good clean down and the the heatsink paste.
styler4077
Further to the known regulator/rectifier problem does.......
Went down the R6 route, fitted and working. Was hoping the original would look a bit suspect but it looks like it was quite happy. I wouldn't be surprised if the ones that give up the ghost are fitted to bikes where the quality control wasn't as thorough. eg, yellow and red onesLotusSevenMan wrote: Can't see the point 'Skidonald' in paying three times the amount for the one you linked to here when the R1/R6 one will do the trick!!!
Try cooling fins I think you'd be nearer the markskidonald wrote:Went down the R6 route, fitted and working. Was hoping the original would look a bit suspect but it looks like it was quite happy. I wouldn't be surprised if the ones that give up the ghost are fitted to bikes where the quality control wasn't as thorough. eg, yellow and red onesLotusSevenMan wrote: Can't see the point 'Skidonald' in paying three times the amount for the one you linked to here when the R1/R6 one will do the trick!!!
- LotusSevenMan
Only I've only been checking this forum out (being a relatively new Storm lover) for a short time I've come to the conclusion that a lot of peeps on here(ie:the yellow or red owners) are bonkersLotusSevenMan wrote:
Yeah probably true as the yellow and red ones are so much faster and therefore harder for the QC people to catch!!!
- LotusSevenMan
skidonald wrote:Only I've only been checking this forum out (being a relatively new Storm lover) for a short time I've come to the conclusion that a lot of peeps on here(ie:the yellow or red owners) are bonkersLotusSevenMan wrote:
