Bigger !! Deeper !! Hole !!!Ckennedy wrote:That's the drink mate.
I may be little Virt but there's supprising strength when needed. I think I'm digging myself a bigger and bigger hole with every word I'm saying :shock:
Op CK stag run - Devon - 25th-27th July 2014
Re: Op CK stag run - Devon - 25th-27th July 2014
Ckennedy wrote:I may be little Virt but there's supprising strength when needed
Grower, not a shower then?
He won't be either after this weekend !Virt wrote:Ckennedy wrote:I may be little Virt but there's supprising strength when needed
Lloyd, I thought I had perverted warped mind, but you have a degree in itlloydie wrote:Bigger !! Deeper !! Hole !!!Ckennedy wrote:That's the drink mate.
Yes 360' :-)Watty wrote:Lloyd, I thought I had perverted warped mind, but you have a degree in itlloydie wrote:Bigger !! Deeper !! Hole !!!Ckennedy wrote:That's the drink mate.
You clearly havnt spent enough time with him Andy a degree is an understatment. Try a PHD!
Ckennedy wrote:You clearly havnt spent enough time with him Andy a degree is an understatment. Try a PHD!
Pretty Huge Richard?Ckennedy wrote: Try a PHD!
Noble prize winner me for chloroform scented lube !!
You should know ymv I had you gagging with a suck !!Virt wrote:Pretty Huge Richard?Ckennedy wrote: Try a PHD!
I only have a small mouth!!lloydie wrote: You should know ymv I had you gagging with a suck !!
Yet I can still get in plenty of trouble with it How did you like the teeth?
I like a bit of bite !! Gets me going !
Kinky tho not wide enough I like Sally the best
And it would still look like this!
