agentpineapple wrote:a secretary dressed in vinyl, now your talking.......... :erection:
You perv Marty...............Sounds good though :thumbup:
Better than Virt in vinyl !!!
Oh I pulled a 3" wood screw out my back tyre this morning ,
Hoping it hasn't gone too deep so I can get home later.
lloydie wrote:Better than Virt in vinyl !!!
Bugger...
The tyre not Virt...Oh hang on this is Lloydie... :lol:
countrymick
Post by countrymick »
took the storm out for a shake down run today,nothing fell off and i have brakes like ships ancors that are only going to get better as they bed in :Bike:
My God :eek2
How thick are your tyres?
It was down to 1mm above the marker and the screw went in just enough to let it down very slowly ,slow enough to make it home and change it .
Mav617
Post by Mav617 »
Paid the mechanic. My valve clearances have been done so picking it up Saturday. Can't wait!
smokey wrote:fabiostar where you get that fork brace from? i been lookin but cant find 1
I got it on fleabay. its actually made for a cb1300, I had to cut the middle section and redrill the holes for it to fit, ten mins work.
bigtwinthing
Post by bigtwinthing »
washed it in anticipation of dry weather Saturday. Going out for a blast with my mate on his newly MCCTed Storm.
bigtwinthing wrote:washed it in anticipation of dry weather Saturday. Going out for a blast with my mate on his newly MCCTed Storm.
I was watching 24hrs in A&E on Weds...Some little lad had been knocked down by a car (nothing funny about that I know...) His dad was explaining to the Mum about the test done so far & came out with...
''He's just been for a CCT Scan...''
Now that did make me chuckle...Do you think the NHS would get a bit peeved if we all turned up & asked for a CCT scan ?
''A&E how can I help''
''My Storms poorly can I get one of them CCT scans please ?''
''Bugger off & stop wasting our time !''
Took fairings off The Custard Crumble & pulled all the conections apart to add dilectic grease to them.
Tuesdays run in to work was a bit on the damp side to say the leaste ! At one point I went through a rather large puddle, no choice it was right across the road, bit of a bow wave, the upshot of which was a bit of a short somewhere resulting in the neutral light staying on no matter what gear I was in. Stayed like it the whole way in & was on & off on the way home.
So that done wrestled the fairing back on & gave it a wash.
Checked all the lights & found a tail light out...brake light was working on that bulb...swapped it over for another bulb...tail light now working...no brake light... :lol: :lol: Try another bulb...all OK... :thumbup:
Lubed up the head bearings for piggy , removed the front wheel bearings from the Brembo wheel ,washed birdie and fitted new rear pads .
Popped into see my engineer to see how he's getting on with the yokes .should be done Tuesday .
one step forward, two steps back, battery fitted, turns over a treat, but it won't fire..... :roll:
I also can't get the horn to work, swapped it out for another one, still won't work, checked the fuse, and that looks ok, i'll swap the fuse over tomorrow just in case. so I've got some serious head scratching to do, or have I just got lice...... :lol: :lol: :lol:
Have you connected the green connection to the right ones behind the fairing
agentpineapple wrote:one step forward, two steps back, battery fitted, turns over a treat, but it won't fire..... :roll:
1st things first...Check the bloody vac line is on, followed by making sure you havent forgotten to turn the fuel tap back on...You have got fuel in it haven't you... :confused
Check the horn by conecting it directly to the battery if it works it's the switch...try another switch, dont have to swap it all over just unplug the switchgear & plug the alternate one into the loom, conect the horn & try it.
