Over the last few days I have been giving Red 633 some attention...
So heres a little spot the difference quiz to keep you ocupied in lock down...
Before...
After...
Frank has kindly donated a small prize as he puts it...'' For the most analy attentive nobheed out there...'' with the most correct answers...
Before...
After...
Just wiped the dust off it again must remember to put bike cover over her or tell the mrs to dust more frequently, yes cover sounds like the best option .
- alanfjones1411
Just a quick look.Stickers,front indicators,rear brake lever,bar ends,can't see on photo properly but screen
Looks black on second pic and clear on first .Still looking good.Begging to be ridden.
Last edited by alanfjones1411 on Mon Apr 20, 2020 5:34 pm, edited 1 time in total.
Removed 1 sticker from tail piece 1 sticker from seat cowl then put V2 sticker on tail piece. Removed 3 stickers from belly pan (double this amount if you did both sides as photo only shows right hand side) Looks like you also fitted clear lenses on front indicators, polished fork lowers and cleaned it to within an inch (2.45mm) of its life. Is that anal enough for you?MacV2 wrote:Over the last few days I have been giving Red 633 some attention...
Before...
After...
- Pete.L
Changed the fence panels and built a wallMacV2 wrote:Over the last few days I have been giving Red 633 some attention...
Before...
After...
Insufferable halfwit.
2.5 Alan...Havent changed the screen it's just the light.alanfjones1411 wrote: ↑Mon Apr 20, 2020 5:21 pm Just a quick look.Stickers,front indicators,rear brake lever,bar ends,can't see on photo properly but screen
Poor effort Duffster only 1 correct... The forks were one thing I gave no attention to....Duffy1964 wrote: ↑Mon Apr 20, 2020 5:32 pmRemoved 1 sticker from tail piece 1 sticker from seat cowl then put V2 sticker on tail piece. Removed 3 stickers from belly pan (double this amount if you did both sides as photo only shows right hand side) Looks like you also fitted clear lenses on front indicators, polished fork lowers and cleaned it to within an inch (2.45mm) of its life. Is that anal enough for you?MacV2 wrote:Over the last few days I have been giving Red 633 some attention...
Before...
After...
Shite effort Pete...The pics are actually from different sides... 1st pic bike is facing the Cave, 2nd pic its facing away...Theres a car parked there currently so I couldnt take the pic from that side...Pete.L wrote: ↑Mon Apr 20, 2020 5:39 pmChanged the fence panels and built a wallMacV2 wrote:Over the last few days I have been giving Red 633 some attention...
Before...
After...
New chain and sprockets, Oberon clutch slave cylinder and a Honda Blackbird side stand
bar ends changedMacV2 wrote: ↑Mon Apr 20, 2020 2:58 pm Over the last few days I have been giving Red 633 some attention...
Before...
After...
Mac,
It Looks like you updated the bell end, and it's still red!
1 correct...must try harderfabiostar wrote: ↑Mon Apr 20, 2020 8:36 pmbar ends changedMacV2 wrote: ↑Mon Apr 20, 2020 2:58 pm Over the last few days I have been giving Red 633 some attention...
Good work that man...
