Ahh ok, you should still get a good pop from your standard can
Ride along at a steady pace (7000rpm on your Hornet), check your mirrors and flick your kill switch to off for around 2 seconds with your throttle partially open, then flick it back on and give all the local Vietnam vets a long and drawn out cinematic flash back! ;)
If it doesn't pop, try increasing rpm before killing the switch, or increase the time the switch is turned off, or give it a fist full of throttle while the switch is off.
If that doesn't work, forget about it and grow up! Learn to wheelie in 1st with those 33 ponies in your right hand
