MacV2 wrote: Tue Jan 10, 2023 3:19 pm Took The Murvinator for it's MOT...
Passed no issues... Apart from it hissing down on the way there, all the time I was there & of course on the way home...!
Tucked it up in the cave, It might be dry tomorrow so I'll give it a wash...
Could be worse the road could have been all salty but it's been too mild for that shite to have been spreading...
Back at home post drenching...
Always good to get the mot out of the way for another year :thumbup:
It’s running again , 14.5v at tickover 😁
No leaks with the new seal kit in the carbs
Well done Lloydie 👍
lloydie wrote: Sat Jan 14, 2023 2:06 pm It’s running again , 14.5v at tickover 😁
Good work Lloydie :clap: :thumbup:
Stuck a new battery in the Pegaso, ten mins tops then 2 hours to get the clock reset :eek2 ..
fabiostar wrote: Sun Jan 15, 2023 4:37 pm Stuck a new battery in the Pegaso, ten mins tops then 2 hours to get the clock reset :eek2 ..
Just remove the battery then install it at the time set by the clock...
tony.mon wrote: Sun Jan 15, 2023 5:51 pm
lol it near came to that :eek2 then the toggle switch decided to work :thumbup:
Thought I’d treat myself to some better carb balancers .
Didn’t take long to get all 4 a lot closer , great but of kit
The new carb balancer seems to have worked out very well 8)
sirch345 wrote: Wed Jan 18, 2023 8:14 pm The new carb balancer seems to have worked out very well 8)
Thanks 😁 wished I picked up a set of these years ago as they make it a lot easier
I use these, too. The only additional advice is to check after they're set by opening the throttle and letting it snap shut a few times as they can settle after setting.
tony.mon wrote: Thu Jan 19, 2023 9:57 am I use these, too. The only additional advice is to check after they're set by opening the throttle and letting it snap shut a few times as they can settle after setting.
Thanks Tony , I did just that after every adjustment 👍
Fitted a usb port for satnav ,I wired it into the old power feeds from the Reg/rec .
Started to make mk2 reg/Rec loom as the new maxi fuse holders came . Just waiting on reg plugs to come , I don’t think it’ll be needed tho but it’ll be good to keep as a spare in the boot if the one fitted melts .
Put it all back together with a rear rack and different tank as the other one had rusted . 50 mile shake down run and all is well except a body work rattle at 4K !!!
Few jobs to do and it’ll be ready for Devon
lloydie wrote: Sun Feb 05, 2023 3:07 pm Put it all back together with a rear rack and different tank as the other one had rusted . 50 mile shake down run and all is well except a body work rattle at 4K !!!
Well done Lloydie 8) :clap:
