Page 1491 of 1529
Posted: Mon Feb 05, 2024 9:00 pm
by sirch345
tony.mon wrote: Mon Feb 05, 2024 11:41 am Today I ordered the tools, oil and seals I need for the Ohlins fork rebuild on my Aprilia. Although they're semi-automatic electronic forks the rebuild looks to be the same as normal mechanical ones apart from unplugging the loom connector at the fork cap. They're not nitrogen-filled, so at least that isn't needed.
It's now done 17k, so it's about time for a refresh, but it reminded me it was due by leaking oil at the recent MOT. :problem:
I already had a 43mm seal slider to fit the new seals, but needed to buy a fork leg compressor. I went for the full-length Sealey one rather than the little circular clamp with two handles. With the full length one you can do the job without a second pair of hands, plus it can be clamped in a vice to hold the leg at a convenient height.
(Thanks for the advice, Jonesy).
I also needed to order the (hopefully) correct pin socket to undo the fork caps. There's no nut, just eight holes, so you need a socket to fit with the pins of the correct diameter and pcd.
I'll know when it arrives whether I measured correctly!
I ordered Ohlins seals plus Ohlins dust seals and Ohlins 5w oil. I fully expect that an aftermarket set would be fine - and cheaper- but I prefer to spend a bit more first time round than have to do the job again in a few weeks, as I had to one time when I used pattern seals on a set of Blade forks I had on my Storm.
So far that lot has cost me £210, which is about what I would have spent taking the fork legs off and dropping them into a suspension specialist. But next time it will only cost me seals and oil.
I'll take some pics and post them afterwards. Ohlins forks are the same as fitted to a number of bikes, e.g. Yamaha, Ducati, etc, so this will be applicable to all Ohlins semi-auto forks. For instance Ducati call theirs Mechatronic, but they should be the same construction, just different dimensions, shimming, spring and oil weight and air gap, so are variations on a theme. But check!
It should be pretty similar to CyberCarl's old thread in the workshop knowledge base, (but without tipping the old oil down a drain)! We'll see, when the orders arrive.
Good luck with that Tony :thumbup: :thumbup:
Posted: Thu Feb 08, 2024 7:11 pm
by Watty
Organised delivery of the new toy :D
Posted: Thu Feb 08, 2024 7:13 pm
by freeridenick
Watty wrote:Organised delivery of the new toy :D
Welcome back. You've been absent for a while I think?
Posted: Thu Feb 08, 2024 8:33 pm
by Watty
freeridenick wrote: Thu Feb 08, 2024 7:13 pm
Thankyou, best part of 10 year I think. You good?
Posted: Thu Feb 15, 2024 8:22 pm
by sirch345
I ordered a new Yuasa battery for the Storm yesterday from Tayna batteries.
Excellent service from Tayna as usual, it arrived today :clap: :clap:
Posted: Fri Feb 16, 2024 8:57 am
by MacV2
Well yesterday...
Took The Murvinator out for a spin...Dryish roads stretched it's legs & mine 60 ish miles.
We may have broken some speed limits along the way... :wink:
Posted: Fri Feb 16, 2024 9:46 am
by ItsaKeeper
Washed the Firestorm chain with kero, dried and relubed with gear oil. I'll probably need to redo the chain sooner than using a stickier lube as the gear oil will fling like the billy-o.
Like a lot of folks I like to treat my bike to a gadget every now and then and as I was in chain cleaning mode I thought there must be something better than cardboard to protect the wheel/tyre from the cleaning & relube splashing. I looked online and the only thing I saw was a 14 quid bit of plastic that you had to cut to the size of your bike's back wheel...back to cardboard I went :lol:
As luck would have my old ikea chopping boards (3 coloured thin plastic A4 ish size) were getting the heave and a single board sits perfectly between the sprocket and hub, protects the wheel/tyre area, allows the wheel to spin without moving the plastic and lets the kero/lube to run down onto the cardboard. All a bit Heath Robinson but works a treat, plus I have 2 spare boards, result :)
Posted: Fri Feb 16, 2024 11:49 pm
by fabiostar
I true me style the Triumph wasnt getting touched :eek2 . well the rear shock is crap in them so a good R model shock went into it tonight. adjustable for everything, even in the cave bouncing on it it feels better,
please winter feck off i want out :thumbup:
Posted: Sat Feb 17, 2024 8:34 am
by tony.mon
Last few days in and off I've been refreshing the fork oil and seals on the Tuono, which is electronic so was new to me.
That's now done, but while I was there I wanted to check out a pulsing feeling I have been getting for a while when braking. It feels like a warped disc, so while I had the headstock stand in (after I finally found a way to lift it without the stand contacting the nose plastics) I checked it with a dti.
The lh side is a bit out, but not by much. The rh side is ok. The difficulty is that there isn't enough undrilled area on the disc for the dti to sit- normally there is a thin path on the outer edge, (but before you get to the rough outer edge of the rim where the pads don't contact) where you can measure accurately. On the Tuono's Brembo discs this is a very small track and the dti tip is slightly wider than the track, so I'm not getting a good reading.
So last year I tried cleaning and rotating the disc buttons. That hasn't fixed it, but I'll have one more try today in case I can get a result that way.
I've also tried removing the disc from the wheel and rotating it 180 degrees in case there is a cumulative machining tolerance error in both the wheel and disc carrier- if so, hopefully, rotating it will cancel them both out and it'll run true, or true enough, anyway.
Otherwise, it's new discs, and I don't have the money for a Brembo set...
I'll also bleed the brakes through with fresh fluid later. They've never been a problem, but the fluid is coming up to five years old now, and seeing as I pumped one piston out a bit far when doing the brake caliper spring clean and saw a little bit of brake fluid before I pushed it back, there's likely to be a bubble or two of air in that caliper anyway.
It would have cost me less in petrol going for a ride every day than it has playing with it in the garage...maybe I have too much time in my hands these days.
Posted: Sat Feb 17, 2024 9:17 pm
by sirch345
tony.mon wrote: Sat Feb 17, 2024 8:34 am Last few days in and off I've been refreshing the fork oil and seals on the Tuono, which is electronic so was new to me.
You forgot the photo's :eh: :lol: :lol:
Glad too hear all went well Tony, fingers crossed on the 180* rotation for the disc issue 🤞🤞
Posted: Sun Feb 18, 2024 7:30 pm
by tony.mon
I've taken the photos, Chris, I'm waiting until it's back on the road before I write up a "how-to" to make sure it all works as it should.
Posted: Sun Feb 18, 2024 9:31 pm
by sirch345
tony.mon wrote: Sun Feb 18, 2024 7:30 pm I've taken the photos, Chris, I'm waiting until it's back on the road before I write up a "how-to" to make sure it all works as it should.
Good man Tony :lol: :lol: I knew I could rely on you :clap: :clap:
Posted: Fri Feb 23, 2024 3:15 pm
by fabiostar
New boots fitted to the trumpet this morning..set of angel GTs.ImageImage
Posted: Fri Feb 23, 2024 9:24 pm
by sirch345
Such a good feeling getting new boots :lol: :lol:
Rob, Is this Triumph Street Triple the big boy a 1050cc engine :?:
Posted: Fri Feb 23, 2024 10:11 pm
by pirks
Removed the front forks and regreased the steering head bearings as I’m sure they wouldn’t have been done since the bike was new.
Changed the coolant as again it definitely hadn’t been done since the bike was new and fitted an optimate 4 battery charging lead.
