Operation Storm Lunatics in London 21st of sept
Re: Operation Storm Lunatics in London 21st of sept
if you do open the throttle when doing the kill switch backfire ................ make sure you shut it again before you flick the kill switch back on!!!!!!!!!!! just saying otherwise you will be practicing your backfires and your wheelies at the same time
on mine it works fine on closed throttle and just 1sec off and back on
I haven't tried one since I had my 1st big bike! 1974' CB550
Jamie
I think someone should compile a 'lunatic' list for this 'lunatics in London' ride, I.e - "must do's" - "can do's" & "do it, we'll stand back and watch through the gaps in our fingers with gritted teeth!"
Jamie
Must Do:Jamoi wrote:I think someone should compile a 'lunatic' list for this 'lunatics in London' ride, I.e - "must do's" - "can do's" & "do it, we'll stand back and watch through the gaps in our fingers with gritted teeth!"
Make the news for keeping Queenie awake all night
Drag race to 30 from every traffic light
Completely unnecessary over-taking of the person in front of you because their bike sounds horrible
Rub into Jamie that nice gold canister on my bike
Compliment Virt on how sexy his Firestorm looks
Let Virt ride your bike because 33bhp sucks ass
Can Do:
Wheelies
Kill-switch backfires
Stoppies
Have fun
Do it, we'll stand back and watch through the gaps in our fingers with gritted teeth!
// ideas pending
My bike was on a permanent backfire riding back from Birmingham
- agentpineapple
for a little bit on the way there aswell......cybercarl wrote:My bike was on a permanent backfire riding back from Birmingham
no real do's and don't guys, try and stay together as a group, make sure your bikes in good road worthy condition, that includes road tax. theres always loads of police in London, but unless they see you doing something dangerous, they'll leave us alone.
do bring a camera or phone with camera.
we will make lots of noise, that goes without saying...
Hahahaha excellent, I'm looking forward to what you have in mind for *pending... Oh actually I'm not sure, please bear in mind I will already have a sore butt from riding around London!Virt wrote:Must Do:Jamoi wrote:I think someone should compile a 'lunatic' list for this 'lunatics in London' ride, I.e - "must do's" - "can do's" & "do it, we'll stand back and watch through the gaps in our fingers with gritted teeth!"
Can Do:
Wheelies
Stoppies
Have fun
// ideas pending
Must do - explain to Virt very clearly, little gold canisters are useless in London, with 33bhp and should be removed and forwarded to the following address...
Jamie,
3, JUST GIVE ME house
YOUR REAR SHOCK street
OR ELSE county
Jamie
My firestorm is fully powered. The restricted bike and the ohlins bike are two seperate entities
Sent from my GT-I9505, written in ASCII using an even parity bit and spoofing the IP of the White House
Must do's
Make sure your cooling system and fan works.
Must remove any baffles that are in place
Must wake up the homeless and get drunks step out in your path
Must not leave people behind that get stuck at lights.
Must keep an eye out the speed camera's
Must control Virt from speeding
I can only do 30...
My fan has never kicked in yet I may have to go for a run tomorrow and leave it running just to check it works lol
It should kick in just after the halfway mark on the temp gauge. if if does not then check the fan works by earthing out the switch at the rear of the right rad. Also check the connector at the front of the right rad and that there are no obstructions in the fan housing itself. You may want to change the fuse as well. As Al's fuse appeared to be OK but when he changed it things worked.
There's a lot of stop starts and a bit of heavy traffic in central London so it's vital that cooling system work properly or you will start overheating.
Will you not be restricting your Storm soon?Virt wrote:My firestorm is fully powered. The restricted bike and the ohlins bike are two seperate entities
Jamie
105 it kicks in on mine
