Right then, more.. pipe has arrived.
I wasn't really happy with the first batch of 50mm from an ebay seller called " 1stopdirect ". It had deep former grooves on every piece & the ends were bashed. Add to that, the box they arrived in was all bust open. Altogether crap service. Consistency..
So for the next batch I ordered from a seller called " 304stainlessexhaustpartsuk ". This seller had postage to add, whilst the above boasted free postage but price was similar when individual parts were added up.
So I took it that they would cost very similar when I added up all the bits. Wrong, the 304stainless seller only charges a one off £4.50 postage. Happy to find out but pissed too.
The 304stainless box arrived yesterday, fantastic pieces. Not a mark on them & boxed up perfect.
Rant over.
So, with lots of bits to fiddle with I popped to the shed & fiddled. This exhaust is costing a small fortune in bends, time & sleepless nights.
The things that have to happen are
1. Mount to the headers.
2. Mount to the silencers.
3. Same length pipes.
4. Look good.
5. Not burn legs'n butt.
It all sounds so simple, but it's grinding me down. You can see why these things cost so much.
I know I keep banging on about Harley exhausts, but to me, they just look good.
The issues I have are that the VTR ports are opposite, similar to an Indian flat tracker, but the Indian exhaust exits on the right of the bike.
Another issue is that the Varadero frame is in the way, this forces the front & rear exhaust outward away from the engine. It is too wide at this point & has to kink in towards the engine to avoid the riders leg.
The frame issue doesn't stop there. As the pipes start to run parallel under the tank/seat, they are forced to go close to the riders butt because of the frame.
This angle is too high for a nice straight run to the silencers, so the pipes have to kink downwards to let the silencers sit at the correct angle.
It sounds a faf, because it is.
As usual, any comments/ideas/piss taking feel free to fire away.
I'm not too happy with it tbh & I'm running out of ideas, motivation & cash, so anything will do at this stage
Here's some pictures, the lower/rear pipe is only for a guide as I ran out of argon to tack up the rear header section
