Post track day inspection
Oil, only dropped to half on the inspection window
Petrol 28l
15mph Low side damage
R&G bar end slider.. Although it took the brunt it was till there when I picked the bike up, but it must have twisted as it slid and then carried on unscrewing as it was missing when I came back in at the end of the session.
Titax lever, slight scuffs but not bent
http://i734.photobucket.com/albums/ww348/amcq46/Mobile%20Uploads/2BCECCC9-4FE1-4472-9EBB-45D4D4B8D882.jpg[/img]
Carbon clutch cover protector.... Slight scuffs but it did it's job
Std end can and rear set peg got a mild scuffing, but rear sets are still straight
Very slight scuff on the fairing wing
Front right Indicator was scuffed on the bottom and the lens popped out. It was also sitting bent up and back. Took it apart and reassembled and it is good as new unless you look from underneath and see the scuffs
Jacket scuffed on shoulder and elbow, trousers and gloves almost unmarked and boots and helmet untouched
So it will cost me £25 for a new set of barends, and I will replace the indicator when I get a nice clean one from CK.
Could be much worse, and it will teach me not to be so cocky and think I have endless grip..and not try and tighten my line when banked right over and getting on the gas on a corner exit. More gas, or tighten the line, not both
![Sad :(](./images/smilies/icon_sad.gif)
