![Question :?:](./images/smilies/icon_question.gif)
I like the Desmo valves... engineering elegance... I note the new Monster has conventional valve gear... the Ducati guys are up in arms
Did that quite some times in the past. A piece of cloth is often enough to block a gear pair.
Funnily enough I was planning to do this to lock the crankshaft in place when I service the Tuono in a week or so, but of course you would need two sections of gear to stop it rotating in both directions. I plan to cut an old gear in half and make up a bracket to fit them on both sides of the primary drive pair.MK_WF wrote: ↑Mon Oct 11, 2021 12:20 pm Meanwhile I do have a cheap, easy and secure method.
Usually you have a spare engine and if you have one gear that'd engage in both other gears, it acts as a perfect lock. If the engine lacks design space, you could cut down the 3'rd gear to a half or smaller piece, just that's it's big enough to engage with the others.
Saves you building individual lock tools all the time...
I did read recently about the Monster having conventional valve gear, but I didn't realise they'd done away with the Trellis frame on that modelbuzzer wrote: ↑Mon Oct 11, 2021 11:22 amI like the Desmo valves... engineering elegance... I note the new Monster has conventional valve gear... the Ducati guys are up in arms![]()
they have dropped the Desmo and Trellis frame on the new model. The purists are horrified
You cant have Desm and cheap servicing though...
Build-up of the engine commences… The tool for holding the flywheel is essential. This one is home made, but they are cheap anyway. When people say wedge a penny in the gears I cringe!
One important thing to remember is there is one special bolt in the cases that acts as an oil feed to the LH case. This needs to go in a certain hole!
The bottle of oil is strategically placed... I am so ashamed of the welding on that engine frame!![]()
I had a little help bead blasting the other day!![]()
