SP1 white smoke - loads of it
Re: SP1 white smoke - loads of it
A bit of a bummer Deano,
I know this will be of no comfort to you, but years ago (1980) when I got my first bike, I thought I would try a drop of the aformentioned stuff. In the vain hope it might make the beast go faster. I mentioned this to my grandfather and he told me not to bother, as a local mechanic sirc late 1940s had put some in the old bike he used as a bobby in North Sutherland (AJS or Matchless I think) after adding it and giving it a run they were delighted, in that all the Carbon !!!! would be gone. Gone indeed, the bike wouldn't run right after that. He said a "good run will do it more good than any additives" words that I will always heed.
A.M.
A.M.
Common sense ain't all that common!
Or it's just voted a new Pope in.....
poping back through the carbs, they're famous for that
Rough justice, after all you were only trying to buy it a drink.
Hope you can get it sorted.
Keep us up to date on the plans, willya?
ta fellas
plans are: its going in the shop on thursday.
if its gonna cost more to repair than the cost of fitting another engine then I'll go the replacement engine route - and the bike will be sold cos it'd be only half the bike I know & love & have bonded with.
also if its repaired but they can't tell me the cause of the problem she'll be sold cos I've lost me confidence in its perceived indestructibility - I really hope now that the cause was indeed the redex.
if its repaired AND they diagnose the cause & guarantee to prevent a repeat then she'll stay and I'll be skint, but happy
if she's sold then the blackbird will be sold too & I'll buy meself an almost new ZZR1400 as me sole bike from the proceeds.
Best of luck with it all Deano
update: head off, coolant in the cylinder but no sign of cracks or gasket blow!
conclusion is the head / block is warped & is more than likely due to too high a concentration of redex in the fuel - so be warned, its fine in small doses but don't overdo it
he's gonna investigate further before skimming the head & reassembling but hopefully back on the road before the end of the month
- firestarter1977
i cant believe this has happend through using redex !!!!!
terrible luck matey , i for one will never use it in any of my bikes or cars again !
all the best
regards mark
all the best
regards mark
the thunder rolls on!!!
Bloody hell, the fastest steam engine was the Mallard at 126mph your steam engine pisses all over that record!!!! lol
Seriously mate, good luck witht he repairs.
Jim.
Jim.
Interesting Dean, lets hope it's not going to be too expensive to repair
he was trying to tell me how much it was gonna cost but I couldn't quite hear him
- Pete.L
Deano said
Could have been a lot worse.
Damn that pesky redex!
Whahoo! Sounds like a result.he's gonna investigate further before skimming the head & reassembling but hopefully back on the road before the end of the month
Aha! Machining top of barrels and head = high compression, equals more power.......
May have to try that Redex myself
Can you skim the heads on an engine with gear driven cams?
Entia non sunt multiplicanda praeter necessitatem
You should be able to get a shim made form a pattern of the head gasket to make up the difference.
Take careful measurements so you know how much was skimmed, and make a spacer the equivalent to the skimmed off thickness.
Or, better still, skim .5mm from the head, and .5mm from the barrel and then use a 1mm spacer.
(Or, use smaller gears- I believe a certain member on here has a gear with one less tooth than normal.......)
