Fork Braces!
cliveyandrews
Fork Braces!
Post by cliveyandrews »
Mmmm, billet porn....!
I am here: http://maps.google.com/maps?ll=50.806514,-1.174208
- Sent from my iPhone using Tapatalk
Audi, Vide, Tace
Re: Fork Braces!
Arrived today, and looks the dogs :D
Photographs and measurements done, and fitted to the bike already :thumbup: Will post them up tomorrow when I can upload them.
Re: Fork Braces!
AMCQ46 wrote:Arrived today, and looks the dogs :D
That's good delivery time from Japan :thumbup:
Re: Fork Braces!
as promised, some pictures
Slotted holes in the top plate to adjust the spacing
plastic rings are most likley glass filled nylon, very rigid
will have to tidy up the dimentions and take photo of that next
Re: Fork Braces!
Cheers for the photo's AMcQ, it looks very well finished :thumbup:
Is it still possible to fit the so called fork leg protectors with the brace fitted :?:
Re: Fork Braces!
Yes I have refitted the protectors, but I think I will have to cut 10mm off the bottom to make sure they don't clash with the bottom yoke at full fork compression
stormingjoe
Re: Fork Braces!
Post by stormingjoe »
My protectors don't hit anything on compression, but did have to put a dab of superglue on to stop them falling off and rattling round on the fork.
gilson
Fork Braces!
Post by gilson »
Do those pieces of plastic actually protect anything? Are they one of those strategically placed deflectors that deflect a large proportion of debris or are they purely to hide the need to make that area between the shiney and the dull look good?
No bike (yet).
Re: Fork Braces!
AMCQ46 wrote:Yes I have refitted the protectors, but I think I will have to cut 10mm off the bottom to make sure they don't clash with the bottom yoke at full fork compression
stormingjoe wrote:My protectors don't hit anything on compression, but did have to put a dab of superglue on to stop them falling off and rattling round on the fork.
Thanks for clearing that up AMcQ and S/Joe :thumbup:
gilson
Fork Braces!
Post by gilson »
Full compression?! Jesus. That's effective stopping that it! I must be more "on/off" with my throttle/brake. No more cruising for me.
I've purchased the same and fitted. I'll be trying it out on Saturday at rockingham's finest.
I noticed that my wheel axel nut was on too tight and all four of my pinch bolts loose! Oh dear.
I think I'll cut the protectors off. I don't see the point in them really.
No bike (yet).
Re: Fork Braces!
Just realised that I didnt finish my report out on this when riding.
At first I thought there was no big difference in normal handleing, but what I realised was that the threshold of where the forks start to "tie them selves in knots" is now much higher, ..............so much more of the time everything feels normal, if you know what I mean.
So end conclusion, is that under heavy braking or leaned over hard on bumpy roads, there is more control and rigidity from the forks........oh and it looks good :thumbup:
next job is to do a tidy up on the drawing and measurements, but will do that soon......or not
Flatline
Re: Fork Braces!
Post by Flatline »
Sounds like a plan, not that I understood a word of it!
How much would one of these cost then?
Re: Fork Braces!
Think I might try some, to see if there's a noticeable difference.
But because I'm tight, I'll try first with a spare top yoke, clamped on the legs where a custom brace would go, which will look pants but do the same job for testing purposes.
That'll stiffen the forks up enough to see whether there's an advantage to be had.
Anyone got one knocking around I could borrow?
Re: Fork Braces!
tony.mon wrote:Think I might try some, to see if there's a noticeable difference.
Tony If you concentrated on one project at a time & got the chicken coop finished........can you see where this one is going?..........then you would have plenty of yokes & wouldn't have to scrounge one. Ba Boom Tishhhhhhh.
I'll get me coat, better make it a waterproof one it's raining.
Re: Fork Braces!
Tony, How are you planning top use a top yoke that normally clamps onto the fork stanchions/legs, when the brace clamps onto the sliders :?:
