Bought my first 'storm
- firestorm1997
- Contact:
Re: Bought my first 'storm
....No not or under the thumb, just have to keep her happy so when I say "I want" she don't argue...
- firestorm1997
- Contact:
Hows the Bike Bacon, any good?
Gets some pics up...
Fried on cans. Or if you want grilled you have to use the cam coverHows the Bike Bacon, any good?
Glad you asked - couple of points;firestorm1997 wrote:Hows the Bike Bacon, any good?
1) was all running fine (130 mile trip home) when opened it up on the final straight in second and it slipped out of gear. Will be changing the oil and looking the clutch cable before I ride it again. Hopefully is nothing serious
2) The service history says that the CCT was replaced a couple of years ago. Take it that it will need replacing again at some point?
Other than that, I freeking loved it. So stable and smooth compared to the SV and feck me has it got some grunt!
I'll get some pics up soon... once it's been cleaned!!
Glad you like the Storm mate, but the clutch is hydraulic not cable.Bacon wrote:Glad you asked - couple of points;firestorm1997 wrote:Hows the Bike Bacon, any good?
Doh!! Needless to say, I will be buying the Haynes manual tomorrow.Kev L wrote:Glad you like the Storm mate, but the clutch is hydraulic not cable.Bacon wrote:Glad you asked - couple of points;firestorm1997 wrote:Hows the Bike Bacon, any good?
What did the CCTs look like? Original Honda or the aftermarket manual 'bolt' kind.
Jumping out of gear could be a problem. Milage? Was it a private sale or from a dealer with a warranty?
Tomorrow If you want I can pop the A12 up to meet you and look over the bike - pm me
Good start but don't rely on it completely, particularly around the CCT replacement section, as the explanation is confused. Use the instructions in the workshop section which is much better. It's also worth looking at the Honda workshop manual PDF in the workshop section. I printed it off for reference purposes ( didn't pay the printing costs though ).
Good luck.
Good luck.
it will do more than rattle if the ccts have failed. I would,nt worry too much if it has oem ones or not. if they are working they are working it just means you got to spend about £40 to change them yourself or pay someone else to do it for you. it would be a priority thoughMiztaziggy wrote:Welcome mate.
Where are you from?
Someone local might be able to come with you to inspect it, it's always a lot easier if you know the bike and know what to look for.
Main things will be, as others have said, engine rattle from failed CCTs and damage to the frame.
hope you like it ? they are great bikes.
how much is a 40k example off of ebay ???
- Miztaziggy
Well, CCT failure doesn't always equal total engine failure, I thought that some have been lucky had it slip only a couple of links.lumpyv wrote: it will do more than rattle if the ccts have failed. I would,nt worry too much if it has oem ones or not. if they are working they are working it just means you got to spend about £40 to change them yourself or pay someone else to do it for you. it would be a priority though
Anyway, Bacon, your priority really should be to change the standard ones for manuals ASAP. If you don't and the OEM ones go and knacker you engine, you will wish you had.
Either that or at least do a stopper mod. So when the original fails it does not cause any damage.Anyway, Bacon, your priority really should be to change the standard ones for manuals ASAP. If you don't and the OEM ones go and knacker you engine, you will wish you had
Some links regarding the Cam Chain Tensioners (CCT's)
You can either go for the stop mod http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=19416
Which is the Honda auto CCT's that are converted to a fail safe. So when it does fail, it don't send the valves crashing.
Or
You go for the full manual conversion, your options are here
http://www.vtr1000.org/phpBB3/viewtopic ... 16&t=22720
Then with regards to fitting View Topic
http://www.vtr1000.org/phpBB3/viewtopic.php?f=31&t=8326
your right really , mine failed whilst the bike was stationary and did no damage to the head / valves at all. there is no way I would have ridden it in that condition though it made a noise like a steel bucket full of nuts and bolts being shaken a lotMiztaziggy wrote:Well, CCT failure doesn't always equal total engine failure, I thought that some have been lucky had it slip only a couple of links.lumpyv wrote: it will do more than rattle if the ccts have failed. I would,nt worry too much if it has oem ones or not. if they are working they are working it just means you got to spend about £40 to change them yourself or pay someone else to do it for you. it would be a priority though
Hi Bacon
It did that when i had it i put it down to an previous owner could do wheels on it(I COULDN'T). You're got K-Tech front springs ebc disc and pads hh castrol power1 oil change every year reguardlist of millage normally 3/4000 tops milage was about 44000 when felic had it.
RIDE TO ENJOY
- Saintsman27
You are very welcome here m8tey.... as a reward when you've got your
Firestorm all gleaming and all running tickety boo ... get yerself down to you local real ale
pub in Witham and treat yourself to the wonderfull real ales available in the town.
I see that there are over a dozen of em and you could try em out one by one slowly .. of course
its a plan ... leave your Honda at 'ome though ...
Alb
Alb
