Disaster has struck. !!!!!!
Re: Disaster has struck. !!!!!!
well done mate, that was the worst I've heard for a vtr starter motor, i'll pm you my details in a bit, as lloydie always says, make sure you lube up everything..... :lol:
BrianC
Post by BrianC »
Had enough with that rear suspension !!!!!!!
BrianC
Post by BrianC »
No problem Marty
If someone can be helped with those bits I'll be happy
It was a real challenge!!!!!
hallie
Post by hallie »
Good stuff Brian. A fair amount of work there
TIP; Never take a sleeping pill and laxative on the same night
http://morrisonbhp.net/
You done well there so it deserves a clap :clap: :clap: :clap:
cybercarl wrote:You done well there so it deserves the clap :clap: :clap: :clap:
That's hardly a compliment Carl :?
:lol: :lol: You made be double check my post then. :Ball Kick:
thunderbolt
Post by thunderbolt »
I reckon I'll need to pull my starter then and clean it up and refit with some lubricant before I let it get to that stage. Although over here we do not have salt and stuff on our roads and don't get the wet weather you guys do, but still worth a check. I reckon we all should do it as a routine as I imagine it does not take that long to get it out (under an hr I would guess).
Thanks Brian for the heads up and
CONGRATS on a task well done :clap: :clap: :clap:
Don
Bikes:
1981 Moto Guzzi 850 T4
1990 Suzuki VX800
2003 Honda Firestorm VTR1000
Big_Jim59
Post by Big_Jim59 »
Congratulations Brian on a job well done. I have been following this thread with great interest and I am totally amazed at both the condition of your starter and the levels of corrosion you guys deal with over there. I guess I am spoiled because cars and bikes just do not rot away here like that.
Well done . Hope the rest if the bike is ok after that
BrianC
Post by BrianC »
Thank you all guys - it was a worrying time, but as per usual great support helps.
Hoping my dust seals arrive today then I can get all the rear suspension rebuilt, get my newly refurbished headers fitted (thanks mac) and then move onto the fitting of the manual cct s
Then my super new chain and sprockets
This is a massive learning curve but one which gas got me back on the spanners again
Who knows , I may ride the thing this summer !!!!!
Brian
Good work Brian, perseverance and common sense pays off :thumbup:
Excellent Brian, well done in taking your time in getting the sucker free :clap:
Well done Brian, corrosion is a fecker on hard to get to places on the VTR I had agro with my linkage and Marty sorted my starter motor due to the nut corrosion. :thumbup:
Grease and lube is the trick, but don't do it when Lloydie is about :lol: :lol: :lol:
BrianC
Post by BrianC »
There we go !!!!!
The replacement starter turned up today, so I checked the contacts and they are great (came off a Firblade\), so I lubed the spigot and o ring, copper grease on the two studs and refitted. Then used a dollop of electrical grease on the contacts and used the replacement cover - job done !!!!
