Quite agree about tyre wear on the road, however not so sure i agree about using the rear to correct corner lines..
Standard:feef wrote:anyone got the stock suspension settings? I might try setting it back to stock and then playing with it from there. i've no idea if it had been played with before I got it.
a
I'll second that KitchKitch wrote:Standard:feef wrote:anyone got the stock suspension settings? I might try setting it back to stock and then playing with it from there. i've no idea if it had been played with before I got it.
a
Forks: preload - 4 rings showing / rebound - 1 turn out from fully in.
Shock: preload - position 2 / rebound - 1 turn out from fully in.
Thats the factory setting, Roger (Firestorm guru and all round top bloke from Revolution Racing) advised me these settings for stock suspension:
FORKS
1) wind the pre-load adjuster (14mm spanner) until only one ring is showing
2) Set the rebound (screw at the top of the fork) until you have "the fastest possible return, but under control" - this will be around 3/4 to 1 turn OUT from fully IN
3) Ride the bike accordingly !!!!
DAMPER
1) Set the pre-load to the LOWEST level (step 1 )
2) Set the Rebound (screw at the bottom of the damper) to "fastest possible return etc. etc. ---"
that's based on me asking for a setting based on my 13 stone and for road / occasionally spirited riding.
well then why recomend it on the NEWBIE thread?slim_boy_fat wrote:Squiffythewombat wrote:Slim-
Simple leave using the rear to the pros.
Thats why I said practice it first, before you need to use it for realOldBob wrote:Back brake . . . My first ever attempt did see me sliding face first down the road
Does the knee count?
How many of you have tried the U-turn without getting your feet down
And remember boys and girls, you'll scuff more of the tyre in fast corners than in slow onesFor all those newbies that want to check how far they can get it over.. draw a line horizontal across your tyre using chalk, then got for a ride, then check out the bits that are left.
That may be the case, but when i did my bike test i was taught to use the rear brake, primarily as a control for doing u turns but also in other situations.Squiffythewombat wrote:slim- Im not saying the back brake inst a tool, i just think advising newbies to use it to scrub off speed in a corner aint the best of ideas....
Whats that surposed to mean?(i guess the entire thread on dragging the rear for sub30 11's was all wrong)slim_boy_fat wrote: But i get the impression that you didn’t realise it could be used to control the bike in a turn.![]()
