Lloydie's track vtr (miss piggy)
Re: Lloydie's track vtr (miss piggy)
What I usually do is take the youtu.be vid title and search for it in the youtube search - which gives more or less the correct URL for adding here
Problem is you've left yours titled by default 'GOPR0128' same as everyone else with a go pro!
lloydie wrote:
Virt wrote:
lloydie wrote:And in simple terms ?
In the protocol part of the URL you make it use an unsecure connection via removing the suffix (which is the 19th letter of the alphabet).
You then ensure you are directly pointing at the video resource and not going through a proxy/obfuscater/whatever the hell they actually are.
Finally you remove all query parameters except for the one that provides the UID for the video resource you are requesting from the server (it has a key of 'v' and is followed by an alphanumeric string that also includes hyphens and underscores).
Better?
Nope .
What part of the link do I need to remove and replace oh young master
[youtube]]
lloydie wrote:[youtube]]
Code: Select all
[youtube]http://www.youtube.com/watch?v=I1_bvYoamVY[/youtube]
[youtube][/youtube]
Thanks Wicky ,
Virt wrote:
lloydie wrote: [youtube][/youtube]
Way to make it work is to not use any URL obfuscators (youtu.be being one of them), and to replace the https:// protocol with http:// (Not sure why https isn't supported but the framework this forum uses is written in PHP, don't really need to say anything else.)
Also if you try to reference a time (Don't think you did), that doesn't work. So the URL can only ever be
Code: Select all
http://www.youtube.com/watch?v={{ video id }}
You da man YMVirt :thumbup:
My memory is doing better than I thought :)
lloydie wrote:[youtube]http://youtube/v-uW9j5bKUY[youtube]
I give up
Mav617
Post by Mav617 »
[youtube][/youtube]
Mav617
Post by Mav617 »
I give up
Fixed above :thumbup:
Thank you but I still can't do it aaareerrs
Code: Select all
[youtube]http://www.youtube.com/watch?v=v-uW9j5bKUY[/youtube]
[youtube][/youtube]
You guys are just showing off now [CRYING FACE]
Good to see the Piggy getting somewhere mate. Now al you need is some (PPP) Piggy Pink Paint :biggrin
