Dyno Day 22nd June 2013.
Griff1977
Re: Dyno Day 22nd June 2013.
Post by Griff1977 »
Al, if you have it and have space to bring, would I be able to use your compression gauge?
Regards. Griff.
Immediate plans:Clean it!
Grif, no problem, I will put compression tester in my tool pack
Told kev to expect us wet or dry :-)
So see you guys Saturday
It would be interesting to do a compression test on that Blue thing I built as well. That's if it's not raining. :roll:
How comes you want to do a compression test then Griff.
Griff1977
Post by Griff1977 »
Carl, it's just that when I broke down a year ago (coil & vacuum pipe at same time!) the hippy mechanic that recovered bike , whilst diagnosing the fault, mentioned that the compression was down on one of the cylinders. Since then the bikes obviously fixed but I want to check compression as it feels a strong engine!
Griff.
well we are at the day before and the Met Office forecast shows that the wolverhampton area will have showeres with some heavy in the middle of the day, and then tailing off mid afternoon.
Thats not real rain, so you will be fine coming up from london mmarr.....mr pineapple
Tools and wotnot packed already including standard air filter. Is JCN 2 on the M5 the best one to take, then cut across onto Oldbury rd/high st and along into cradley heath.
J 3 is better..........the route fom there is easy enough
see you tomorrow :D
Virt
Post by Virt »
Or just use sat nav :wink:
Wonder how many times I'll get myself, the friend and gazfirestormowner completely lost :wink: :lol: :lol: Oh this will be fun
Google maps is more reliable than satnav. Then it's in my head and I don't have to keep looking at, and relying on something else to get me lost. :biggrin
Gazfirestormowner
Post by Gazfirestormowner »
Can't wait to get lost with virt and his mate lol im sure it will be an enjoyable ride either way
Virt
Post by Virt »
Damnit you weren't meant to see that :lol: Nah, should be fine. I have the general idea anyway, sat nav is only there in case I forget...
Gazfirestormowner
I'm sure we will find a way there 3 heads should be better than 1 lol
Virt
Post by Virt »
So the theory goes! :lol: Let's see how many more laws of common sense I can break in my lifetime :twisted:
Gazfirestormowner
Lol see u at asda petril station at 8.45am
