You can offset the effects by using a K&N or similar, but a Dynojet or Factory Pro jet kit will be most effective.
But as long as you do a plug check in the first few days you shouldn't do any damage- the risk though is that it'll run lean and burn a hole in a piston or burn out a valve seat.
However, please don't panic
