electrical problem ?? or is it?
bikerpiker
Re: electrical problem ?? or is it?
Post by bikerpiker »
Well done that man ..... :D
It was just a pity none of us were closer to help, you're 99 miles from myself and cupasoop , but as has been said ,we wouldn't have been able to help anyway ,sounds like a top mechanic you've got there :!:
Stevie
mwross1964
Post by mwross1964 »
Mechanic is
Daryl Porter
c/o BCG Bikes
Galashiels
Scottish Borders
01896 751997
my bike might be fixed by end of next week,but it depends how busy he is,just in time for the rainy season no doubt,lol.
mark.
anything with wheels or tits is gonna cost ya money.
but who needs money
mwross1964
Still waiting on parts !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
took the chance (while all the upper & lower fairings are off) to give the bike a good clean, right into bits you cant usually get to,used a de-greaser spray & even if I say so myself, it looks very good for a '98,no body or swing arm problems I could see that would make alarm bells go.
mark.
but who needs money
You might want to strip, inspect and re-grease the suspension linkages- see the posts on here for more details (it's a sticky in Workshop), especially if you've been spraying de-greaser round them!
:wink:
mwross1964
didn't go near the suspension!
mark.
but who needs money
mwross1964
Bad news,just been told the engine is wombles.as well as the oil pump chain comming off,looks like the timming jumped and you know what that means....
its going to cost me £170 for the garage to take out the engine and strip it down to see exactley what the hell is damaged...but I have to find out so I told him to go ahead.!!!!!
only been out on it about 5 times.
wombles wombles wombles..
:mad2
but who needs money
marravtr
Post by marravtr »
feck! gutted for ya matey
Phil-VTwin
Post by Phil-VTwin »
If the timing jumped due to the same reason then that is the rear cylinder, good news is that there are plenty of good rear heads available as normally its the front that gets buggered with cct failure.
Ride Safe
Phil
Gutted for you too matey :!:
warby221
Post by warby221 »
Sorry to jump in
But could I raise a couple points
Are you sure the oil pump chain went south????
If it did then there’s a good chance the bearings are shagged and with the other damage cut your losses and fit a good second hand engine you should pick one up for £200-300 then its just fitting it
I’m sill finding it a bit strange that your having problems with to chains in the engine at the same time
Are you sure that the first prognoses was right with the oil pump if not and its just the valves that are bent this can be sorted without taking the engine out it’s about £30 for the head gasket, the valves are off hand £16 each and when the valves get bent it’s usually two of them that go it so that’s £32 and a set of new CCT while the heads are off hole lots just over £150 in parts and gaskets
If you know some one that’s handy with the spanners and workshop manual you could strip the head of the engine and have the bike shop fit the new valves and refit the head and save a fair bit on labour costs that’s assuming the pump chain didn’t go
mwross1964
its wombles.
need to cost a 2nd hand engine to see if its worth it.
can anyone help!! :(
but who needs money
