Did you actually try the rear HT coil (the one on the bike that is showing a good spark) on the front cylinder I realise you say you swapped coils, but was that for a spare 2nd hand coilGr8whenitgoes wrote:Carl Thanks for the quick response and the welcome, and yes I have new plugs, and have swapped coils/leads and fitted 2nd hand ignition and converter units - no change!cybercarl wrote:Correct it's a lost spark system. It may sound silly bit have you changed the plugs. Swap the coils and leads over and see if the problem reverses to rule out HT lead and coil.My understanding is there is a spark on every rotation of the crank
Welcome to the forum.
Regards
