K-tech fork springs
popkat
Re: K-tech fork springs
Post by popkat »
VANSTUB...
who knows best K tech or Brookes suspension*.... I'll tell you...K tech, no question. they also agree with my findings which I came to 16 years ago, before this forum and before K tech..
Race tec are known to quote spring rates that are too heavy.
I'll say it for the last time.... for you type of riding and weight 0.85kg springs...
*Brookes suspension rebuild suspension as far as I'm aware, they are basically a service centre not a suspension specialist, whereas K tech, Maxton etc do the lot and Are suspension specialists. Brookes are probably just quoting the racetec rates from a chart :roll:
NZSpokes
Post by NZSpokes »
Ive found it to be bang on. Static sag and rider sag have been perfect. Both road and dirt.
Dendrob
Post by Dendrob »
Unless you weigh considerably more than average, I'd be tempted to listen to popkats advice.
As a matter of interest, what is the rate(s) of the stock spring? Is it dual rate?
vanstub
Post by vanstub »
popkat wrote:VANSTUB...
okay popkat i fully understand now,wasn't questioning you just got overloaded with info from t'web 0.85/8.5 n/mm spring it is
appreciate you help and with choice of fork oil :thumbup: sometimes i need a good :Ball Kick: to set me right :clap:
Life's too short for plain biscuits :thumbup:
popkat
Post by popkat »
Your welcome, I wasn't being stroppy or having a go, just trying to get the point across :) :thumbup:
Roger Ditchfield
Post by Roger Ditchfield »
popkat wrote:Yes I have 0.85kg K tech springs in mine, they are drop in using the standard spacers, I have 10wt oil and 140mm air gap, preload set to 25mm, forks dropped 5mm through, you need to drop front as the springs make the bike sit higher at the front (as standard they sag more), might go down another 5mm on mine for the summer.
Do not drop down more than another 3mm max
popkat
Post by popkat »
I have run the forks 10mm through before Roger, that was on the one I raced a bit and it had a steering damper, I did pull it back to 5mm when I sold it though..
I don't think i'll drop these anymore now anyway though as I can adjust the ride height on the WP shock.
just to throw another penny into the ring, iv seen Wurth (I think that's the name) front springs on ejey has anybody used those?
Mav617
Post by Mav617 »
fabiostar wrote:just to throw another penny into the ring, iv seen Wurth (I think that's the name) front springs on ejey has anybody used those?
Just bought some (Wirth) for the TRX but not sure if they're good, bad or indifferent as not fitted yet. Mine had K-Techs supposedly fitted, but the front isn't the best, might have been for an 8st rider and they are almost 20 years old! Let you know if they make a positive difference.
popkat
Post by popkat »
Not sure K tech were around 20 years ago, if they were then it was early days and I doubt they were selling fork springs. iirc they started out on dirt bike suspension then moved to road race bikes before doing road stuff.
Mav617
Post by Mav617 »
Sorry mate, should have been clearer - the bike is 20 years old, not sure when the replacement fork springs were put in but the front is decidedly soft even with new fork oil in (standard weight/air gap)
