How to remove and refit CCT's on the Firestorm
Pleased too hear all now seems to be well Satanzhand :!: :D
PS. Good advice in your last post IMHO :!:
satanzhand
Post by satanzhand »
thanks,
The bikes running mint. I've been pulling wheel stands from the lights all week (even with my extra winter bulk, lol).
JohnD
Post by JohnD »
Just wondering...
...is it absolutely necesary to retract the plunger on the CCT before you remove it?
Only reason I ask is because last time I did it I found it to be a bloody pain in the A**E !!
Fitting my APE's this week hopefully... & I can't wait to be rid of the Honda Achilles Heel !!!
:D
JohnD wrote:Just wondering...
:D
No, it's not necessary to retract the original CCT's plungers before removing them :!: IMHO you're better off not retracting them fully before removal, especially if you're going to re-use them, as all you are doing is putting unnecessary strain on the spring :!: If you don't have a key to fit in the end so they can be locked before removing just put a small slotted screwdriver in the end and hold the worm/screw where it is. All you are doing is taking the load off the plunger from the spring, so that it's easier to remove the fixing bolts and the CCT itself :!:
JohnD
Post by JohnD »
Cool. Thanks for the clarification :D
John
satanzhand
If your not going to use them again don't worry about it.
Jim67
Re: How to remove and refit CCT's on the firestorm
Post by Jim67 »
Might sound like a daft question but you mentioned re-fitting the metal caps on the plungers, do you have to fit them on the the ape tentioners too??
Cheers,
Jim.
RACIST!!! not me....I'll race any fooker!!!!
No Jim,
the caps don't fit on the APE tensioners but don't worry the tip of the tensioner is metal anyway and slightly larger than the Honda one if my memory serves me correctly.
Jim67
Post by Jim67 »
Cheers for that pete.
Jim.
Jim67
Post by Jim67 »
sirch345 ...... many thanks mate for the info you posted, I followed it to the letter and didnt put a foot (or spanner) wrong!!!
Brilliant and informative !!!!!
Cheers,
Jim.
Well done Jim :!: glad too hear all went well :D
Collywog19
Post by Collywog19 »
b8stard inspection centre cap. So bloody soft. Thing is ive had it off before when i fitted a new front oem tensioner. I came to fit my manual ones today and rounded the b8stard thing off!
New one needed if anyone has one lol. Or i'll just order a new one from david silvers.
Col
Bikes ftw!
firestarter1977
Post by firestarter1977 »
just grind a slot in it col ,
thats all i did then welded a bit of 25x6 flat to a socket to remove in future lol
8)
the thunder rolls on!!!
IgorVigor
Post by IgorVigor »
Thanks Chris
Followed the procedure when I fitted my manual tensioners...
Don't know whether it is just my bike but there seems a lot of safe adjustment between the cam chain rattling and the chain chirping :S
I think it was 2~3 full turns :S
I adjusted mine by backing them off until the cam chain rattled and turned them back in until it stopped and then 1/2 a turn further...
No rattles at all and the engine does seem to pull better now...
But most of all, I have peace of mind that the damn tensioners aren't going to fail at any minute :P :oops:
alan g
Post by alan g »
Thanks for the expert instructions Chris,
I followed them to the letter and had no problems at all, thanks.
I’m sure there were photo’s with the instructions at one time.
Thanks again.
Alan
