Project Varatrackerstorm or Firetrackerdero.
Varastorm
Re: Project Varatrackerstorm or Firetrackerdero.
Post by Varastorm »
sirch345 wrote: Fri Dec 21, 2018 8:19 pm
What an amazing find :clap:
Another option if you're not getting maximum rev's, is to use one twin choke carb per cylinder :wink: :shh: Not that you want to be making new inlet manifolds I'm sure :)
:lol: Now that's a thought :thumbup:
I did a similar thing years ago Chris, I made a 4 into 2 manifold for a pair of Dhla Dellorto 40's for an old mini.
I made it from stainless, it was smart too. Never tried it on an engine though & eventually binned it in a council skip :crazy: Air speed would be too slow for atomisation apparently :problem:
It was 1987 & love was in the air... Women, more trouble than any friggin manifolds Ill tell ya :lol:
Varastorm wrote: Sat Dec 22, 2018 7:06 am
:lol: those were the day's, they just went too quick :crazy:
Getting back to your project, see how the bike goes with what you have already, if it starts to run out of steam at higher rev's, see if it's a huge problem first would be my thoughts. At least you have plenty of options carb-wise now :thumbup:
just a curved ball here. have you checked out any Lectron carbs? as in from race bikes of yore :eek2 . they run a powerjet system that for want of a better way of putting it, give the engine an extra juice boost.
Varastorm
Post by Varastorm »
sirch345 wrote: Sat Dec 22, 2018 3:44 pm Getting back to your project, see how the bike goes with what you have already, if it starts to run out of steam at higher rev's, see if it's a huge problem first would be my thoughts. At least you have plenty of options carb-wise now :thumbup:
That's the plan Chris, tbh the bike will only be a toy. I'll use it to go around the Island & if it behaves, maybe attempt the odd track day.
I'm quite happy with my carb selection & hopefully one of them will work well, but those 50's were a little bit too expensive this time of year :shh:
Once I dig the plasma cutter from under the tree & strip the wrapping off it, there'll be no stopping me :lol:
The friggin battery box will be a thing of the past, well.. hopefully :thumbup:
fabiostar wrote: Sat Dec 22, 2018 4:20 pm just a curved ball here. have you checked out any Lectron carbs? as in from race bikes of yore :eek2 . they run a powerjet system that for want of a better way of putting it, give the engine an extra juice boost.
Double curve (loop) ball Fab, if I find that these carbs will not work :eek2
I'm going to be looking into Turbo charging :beer:
Back in the day :roll: , I used to have a Renault 5 Turbo. I did a lot to it & it was a proper laff.
The design was a simple blow through carb arrangement. From turbo to intercooler to carb, job done. Sorting ignition retardation to avoid detonation might be a problem :think:
With all the tools I've had over the last year it should be possible. I've already got an eBay search for a Renault 5 Turbo turbo :crazy:
Never mind Pikey Hoarder, is there such a thing as a Carbaholic :lol: :thumbup:
Oh well, back to tackling charity muggers & buying stuff no one really needs. Aka Christmas shopping :lol:
i know a few car hoarders used to be into 5 turbos so il have a word in a few ears...
what about Toyota startlet turbos? or Fiat uno units?
Varastorm wrote: Sun Dec 23, 2018 10:00 am
Ah the first sign's of positive thinking on the battery box :clap: :clap:
Varastorm wrote: Sun Dec 23, 2018 10:00 am Double curve (loop) ball Fab, if I find that these carbs will not work :eek2
:lol: :thumbup:
Varastorm
Post by Varastorm »
Progress is super slow atm, life & weather have been a bit rubbish.
So I've found comfort in good ole eBay.
Walla..
It's a 1944 Myford M type.
I always wanted a lathe, but with them being so big'n heavy & usually miles away I never thought it would ever happen.
Then I saw this, the previous owner has converted it to 3 phase with an inverter & it runs so smooth.
We carried it down to the shed & feck me it's heavy. More than likley it'll hardley get used, but when I need one it's there.
All thats needed now is room for it :roll: :thumbup:
Varastorm
Post by Varastorm »
I have been busy, just not on the tracker project. I had too many jobses going on & every time I worked on the tracker I felt guilty.
So I have been doing some motorbike house keeping :)
I fitted a new (£60 Chinese) radiator to the Cbr600 which led to blowtorch medical attention to all the exhaust studs & a major carb overhaul. Job done & now runs like a watch again. Tick.
I also sorted out the Varadero's rear saggy ass shock issue once & for all. The Varadero (Project Varastorm) is now officially completed, bar fitting the new battery. So that's also sorted & runs like a watch too. Tick.
All that's left to do is make room for the Lathe which'll require some nicer weather to aid a major "Handy stuff/Pikey hoard" movement & it'll be all systems go.
I think :think: :thumbup:
Varastorm
Post by Varastorm »
Right then, many moons ago I mentioned making a shortened twin shock swingarm from steel.
This was my original idea.
I originally was going to copy the internal dimentions of the Vtr swingarm pivots & turn down some metal rings/pivots so original bearings & oil seals could be fitted.
Then copy/use a say an old Cbr600f3 swingarm arm for the simple chain adjusters. After all they're only rectangle box section with slots milled on them. If the Cbr arms are no good, I was going to make some new arms from rectangle box & use the lathe to mill the adjustment slots in them.
Then weld it all together.
But, last night I came across this.
It's a steel 2011'ish Cbf 1000 swingarm. I've measured & cross referenced as many things as I can & think it might work.
It's going to get chopped narrowed shorten widened... but it pivots the same way as the Vtr/Varadero on 20mm bearings for a shaft. The pivot bearings should be fit for the job & I've just had the adjusters that fit it also.
I'm not sure what brake will be used & it could be another waste of time & money, but it's only cost me £30 all in :thumbup:
You certainly are a busy man.
top class lathe porn may i say..
so you can see the light at the end of that LONG tunnel :clap: :clap: :clap: :clap:
pictures or it didnt happen :lol:
cant beat having a lathe in the shed, I got one just before Christmas.
but I bought something a fair bit smaller based on available room in shed and the reality that I will only use it for spacers and smaller items. ... I am not going to be doing flywheels, we have Fabio for that
for some reason I would rather have a 1930 british bit of kit than a modern Chinese toy, but I thoink that same philosophy shows up on all of in this forum....... otherwise we wouldn't be modifying VTRs :lol:
AMCQ46 wrote: Fri Feb 01, 2019 1:20 pm cant beat having a lathe in the shed, I got one just before Christmas.
how very true Al.... old is best and that goes for bikes/lathes/women. oh maybe not that last one lol
what did you get? lathe wise
Varastorm wrote: Fri Feb 01, 2019 8:03 am Progress is super slow atm, life & weather have been a bit rubbish.
Walla..
What another lathe owner, brilliant :clap: 8)
And you too Al, excellent :clap: 8)
Not that I'm envious or anything :wink: :lol:
Varastorm
Post by Varastorm »
What lathes have you guys got then? Any top tips about tools or methods etc?
Those pictures of the lathe are from the sellers shed, you'd give me a right talking to if you saw it in mine :lol:
He also chucked in a load of "handy :roll: " stuff with it too. Things like a 4 jaw chuck, centres for the tailstock, dti gauge, whole set of new carbide tipped tools, the old motor & cast iron wheel/tensioner stuff & many more bits.
He also gave me a book called "The Amateur's Lathe" by Lawrence H. Sparey" cracking read" so much so that I get cramp in my legs after a good ole crap :lol:
I've just received a cheap magnetic dti gauge from ebay & a more expensive American item is on the way.
I initially bought just the lathe with the old electrics, but when I went to see it & saw it in action hooked up to the modern motor & inverter gizmo that I just had to have it. In his shed I came to the conclusion that he knew a lot more about lathes & electrics than me. He'd also put a lot of thought & work into this upgrade & it must of been for a reason.
The long (30 paces) to the car was difficult, in the car the conversation went a little like this..
Hi love, sorry, I didn't realise I'd been there over an hour..... Really nice guy, yeah.... he's also got some other bits for sale........ I was thinking....... if I/we don't get it all as a unit I'll/we'll regret it later..... how lucky I/we were going be to own such a fantastic life changing machine.... :lol:
I also had to promise a heap of other things, but hay ho, I/we got ourselves a lathe :beer:
