Page 318 of 1529
Posted: Sun Apr 14, 2013 2:24 pm
by tattoo
only thing i done today was hook the rear view camera kit upto the bikes battery and taped the monitor to the right hand mirror....RESULT...the image is the right way round :thumbup: :thumbup:
Posted: Sun Apr 14, 2013 3:48 pm
by cliveyandrews
cybercarl wrote:
Easy enough with a new drill bit Marty, fortunately I have a bench drill so that made it easier, too easy to slip with a hand held drill
I use a cone cutter for getting the heads off rivets.
I dread to think about what the condition of my packing is. Bit they sound so good, I don't care. :roll:
Last time I cut the rivets off an end can, they kept spinning, both with a rivet drill and a cone bit. In the end I had to cut them off with an angle grinder. Hope I have more success when I shorten Pauline's cans....
Sent from my iPhone using Tapatalk and my fat thumbs...
Posted: Sun Apr 14, 2013 3:49 pm
by lloydie
Washed it and changed the front sprocket back to a 16t .
Posted: Sun Apr 14, 2013 5:57 pm
by MacV2
Finished the re pack.
Right hand can the old packing was full up...?
Still took it all out & put the new stuff in. As predicted got it done a lot quicker still a faff getting the new packing in.
http://s1242.photobucket.com/user/macV2 ... c.mp4.html
Posted: Sun Apr 14, 2013 6:04 pm
by agentpineapple
MacV2 wrote:Finished the re pack.
good work dude :thumbup:
sounds good mac, have you got any air leaks on the exhaust as shes popping a bit, or is that how it runs on those harris cans???
Posted: Sun Apr 14, 2013 6:16 pm
by tony.mon
Often the case, mate.
The LH can gets more gas going through it, because of the little blanking section inside the collector.
So the packing gets blown out quicker, unless you have cut the intruding section away, then you get even pulses out of both cans.
Posted: Sun Apr 14, 2013 6:32 pm
by MacV2
Thought that was the case Tony.
What was the answer to the discussion on weather it was worth cutting that section out ?
Posted: Sun Apr 14, 2013 6:33 pm
by lloydie
leave it alone mac as removing it creates a flat spot in the revs .
just had another hour in the garage .
going over the bike with copper slip and getting it ready to commute on .
i fitted the baffle too :(
Posted: Sun Apr 14, 2013 6:36 pm
by agentpineapple
lloydiecbr wrote:leave it alone mac as removing it creates a flat spot in the revs .
baffle fitted too :(
i can't believe froggy is going to be a daily commuter, put lots of wax on the bike and don't get to close to other road users, you don't want to get loads of stone chips, just ask old man kev......... :lol:
Posted: Sun Apr 14, 2013 6:38 pm
by MacV2
bigspanishmarty wrote: good work dude :thumbup:
Nowt wrong with a pop now & then Marty sounds good on the overrun IMO.
The link pipes are just a push fit onto the cans held with springs so I guess a bit of air can leak in that way.
TBH when it revved it kind of overloaded the microphone a bit, so the sounds a bit distorted as well.
You can also see the bits of fibre being blown out already !
Posted: Sun Apr 14, 2013 6:39 pm
by lloydie
i know but at least i will be commuting down 20 miles of fast biking roads each way :D so i will be having fun on it every day :thumbup:
i went to work today on the frog and it was great even in the wet/salt/farm crap covered roads 8) .
Posted: Sun Apr 14, 2013 6:40 pm
by MacV2
Yeah thought that was what was said...
Dremell is staying in the case then.
Posted: Sun Apr 14, 2013 6:45 pm
by lloydie
the standard exhausts have had the dremeling the leo has a removeable baffle .
i need to get some collector graphite gaskets and clamps for the stock system and a standard air filter before the dyno day 8O
Posted: Sun Apr 14, 2013 6:54 pm
by agentpineapple
lloydiecbr wrote:the standard exhausts have had the dremeling the leo has a removeable baffle .
me and carl were doing the exhaust today, pain in the butt, even with those gaskets, making sure you have the correct sized mikalor clamps. even then i've had to put some sealant on the joins. i took some pics of my bike with carls proper camera, i'll see if he can email them over to me so i can see them.
mac the cans sound good, i rode behind you at wickys, and when we went thru a couple of small villages your cans followed by my ti system sounded biblical bouncing off the walls ..... :lol: :lol: :lol:
Posted: Sun Apr 14, 2013 9:09 pm
by gaz_vtr
Actually got to ride it today! Following a few days in the garage removing the front end, resprayed the forks, carbon wrapped the fork protectors,refitted everything and got the front wheel and bars aligned after noticing last week that they were pointing in slightly different directions! All sorted and felt great, wish they would fix the roads though, they're a right state.
