darkember
Post by darkember »
cybercarl wrote:Don't throw the old bearings away just yet as you can use them to to help get the new ones in place. You don't want to directly hit the new ones with a hammer, so can use the old ones over the top and hit them instead. When you get the new one's, put the outer headstock race in the freezer overnight and then they will shrink a bit and be easier to knock into place. An angle grinder works a treat to help remove the old bearing off the steering stem. A combination of heat from cutting and cutting it off, and it will slide straight off before you even cut right through it. If you have a bit of metal tube or copper pipe slightly larger than the steering stem, this will work well to squarely knock the new bearing down into place. :thumbup:
Not forgetting to put the dust cap on first :D :D :thumbup: :thumbup:
And to have the taper pointing in the right direction. :lol:
cybercarl wrote:And to have the taper pointing in the right direction. :lol:
And don't mix and match the old and the new races and cages like Virts Hornet!
Virt
Post by Virt »
But it handled so good :lol: Totally didn't have loads of front end wobble or anything
Removed the inlet restrictors from the exhaust headers .
Fitted new bushes to the forks but there's still a little lateral play !
Stanchion are fine so I'm thinking the lowers are oval . I will refit them tomorrow and see what they are like .
And took delivery of these
So tomorrow I will show them up to the frog and have a think !!!
lloydie wrote:Removed the inlet restrictors from the exhaust headers .
use the akra's and sell the quills to me on the cheap, you know it makes sense....lurvly jubbly..... :D
darkember
Post by darkember »
No difficulty there as the old ones are prehistoric ball races type
I'm picking up the akrapovic on Sunday .
So Sunday night one set well be for sale not cheap mind but will be at cost . :-)
So were the ones on Virts bike !
lloydie wrote:I'm picking up the akrapovic on Sunday .
and i thought you were my friend............. :cry:
You have the TB's which are much better. It's just a shame they are not TI.
ssssssh!
i'm hoarding again..... :wink:
nah i'm just testing lloydie friendship, and he's failed terribly..... :roll:
Don't worry, the sheep will get bored soon. :lol: :lol:
cybercarl wrote:Don't worry, the sheep will get boned soon. :lol: :lol:
Fixed :-)
ssssssh!
:ballkick:
A member already has first dibs on the set I sell . I will mark you down for seconds :-)
