Page 383 of 1529
Posted: Thu Jun 27, 2013 10:33 am
by Nickcv
Got around to fitting my rear hugger :D
Posted: Thu Jun 27, 2013 10:34 am
by agentpineapple
Nickcv wrote:Got around to fitting my rear hugger :D
don't forget to post some pictures of your modifying progress nick.... :thumbup:
it all adds to your post count.... :wink:
Posted: Thu Jun 27, 2013 5:11 pm
by 8541Hawk
AMCQ46 wrote:Good work Carl and Hawk :thumbup: Wouldn't have guessed that...
It's just that I have been around these bikes for too long as I had seen the problem before. 8)
The funny part is a guy on the US forum had the same issue but didn't believe me and I believe he ended up selling the bike. :confused
Posted: Thu Jun 27, 2013 6:37 pm
by Redthunder
Collected paint and spent evening flattening panels 8O
Posted: Fri Jun 28, 2013 12:11 am
by VTRDark
Spent the day with Ole Red and the Yellow thingy. Turns out it's French :roll: Got the subframes and swingarms swapped over. Pretty much the whole rear ends. I had a one armed bandit to help get in the way and do some light tinkering.
Posted: Fri Jun 28, 2013 10:16 am
by MacV2
8O
Posted: Fri Jun 28, 2013 10:31 am
by seb421
Yesterday Disabled the Exhaust Valve on the GSXR, when removing the wire from the ECU plug found some cowboy instead of pulling it out the plug had just cut the wire in the past
when putting it back together and the original can back on the wire had just been twisted back together and a bit of tape on it 8O no solder or anything
Sorted out the idle and fast idle speed too, ordered a new genuine filter and iridium plugs
Bike rides better now the valve is disabled, its louder a lot louder feels a different bike and sounds completely different under 6k
Ordered a new Genuine Suzuki air filter and iridum spark plugs too :thumbup:
Posted: Fri Jun 28, 2013 7:28 pm
by 8541Hawk
Just got the news that my shock is going to ship out today........
So next week I get to ride :thumbup:
Guess I better get to work on changing the bearings in the Gilles rearsets so I can pop those on also......
Posted: Fri Jun 28, 2013 7:32 pm
by AMCQ46
Removed the barrel off the KH125 and took it and the 1st oversize piston off to PJ engineering to get it rebored.
Don't you just love 70's air cooled 2 strokes, how simple they are to take apart...
Quess how many bolts had to be undone to get the barrel off?
Posted: Fri Jun 28, 2013 7:58 pm
by VTRDark
That good news, it about time. :thumbup:
Four
Posted: Fri Jun 28, 2013 8:02 pm
by AMCQ46
cybercarl wrote::
Four
Nope....you need to go up a bit, remember to factor in removing bodywork and inlet / exhaust.
Posted: Fri Jun 28, 2013 8:09 pm
by VTRDark
Nine.
Could you slide the top off without removing the lump.
Posted: Fri Jun 28, 2013 8:17 pm
by AMCQ46
cybercarl wrote:Nine.
Too high now :D
Posted: Fri Jun 28, 2013 8:20 pm
by lloydie
7 :-)
Posted: Fri Jun 28, 2013 8:44 pm
by AMCQ46
lloydie wrote:7 :-)
Correct...
Removing the tank...0, it just sits on rubbers
Removing the carb...0, it's a disk valve engine so the carb is on the crankcase
Removing the exhaust...2 bolts on the barrel and 1 that joins the header to the silencer
Removing the head...... 4
Removing the barrel....0, it's held on with the long studs tat hold the head
=7 :thumbup:
