I didn't googje it no :-)
Gazfirestormowner
Post by Gazfirestormowner »
Today I reset cam timing and fitted manual tensioners just the carbs to sort and it will be time to fire it up and see if it runs any better
Well done Gaz, how did you get on moving from the rear to the front and did you turn the crank a few revolutions once finished to make sure everything turns over smoothly.
Just put the carbs back to standard to begin with.
Mains Front 175 Rear 178 and double check the emulsion tubes are the right way around
Needles are non adjustable
pilots 48
fuel Mixture screws 2.5 turns out front and 2 1/4 on the rear
Gazfirestormowner
Yeah got on we'll mate it's now 1 1/4 turns from rear to front and everything is spinning over nice and free I have checked emulsion tubes and they were correct just need the jets and will check mixture screws and hopefully it should be all good.
Will be a bit nervous when I'm pressing the start button but think its looking good.
Thank for all your help and advice.
:clap: :clap: :clap: Excellent..... :biggrin I'm looking forward to your first post after taking it for a proper ride. As for being a bit nervous, that never leaves you. I still get a bit nervous after doing work like that and pushing the button. The only difference is that you get used to it and learn not to question yourself or abilities. :thumbup:
If you need jets Gaz give me a holla :-)
Gazfirestormowner
Might do that lloydie am waiting on a call in the morning to see if I can get some but I think their too big for most people to keep in stock. Cheers
Gazfirestormowner wrote:Might do that lloydie am waiting on a call in the morning to see if I can get some but I think their too big for most people to keep in stock. Cheers
Careful as to what range they are fome- Keihin, Dynojet, Factory Pro are all different....
tony.mon wrote:Careful as to what range they are fome- Keihin, Dynojet, Factory Pro are all different....
Well Keihin and FactorPro are "supposed" to be the same though DynoJet has its own numbering system, with that I personally don't mix brands and just use Keihin jets in my set up.
Keihin and FactorPro are exactly the same. This is why they don't supply 175 and 178 mains in their kits and say in their instructions to use the ones in your carbs if required. But Tony already knows this, he's just getting old. :lol:
Yeh Dyno jets are your main concern as they are totally different in the sense of sizing and how they fuel your carbs. And agree that they should not be mixed with standard or non dynojet needles. This just makes things tricky to get right.
callam_nffc
Post by callam_nffc »
Had a set of pilot road 2s fitted, fingers crossed they give me what I want :)
CBR125 - XJ600S DIVERSION - YZF600R THUNDERCAT - VTR1000 FIRESTORM
I still crave a supermoto...
Round two of Rape Red for the good bits...
Cheers Carl ... :thumbup:
Long day in the sunshine, Red's forks were slightly bent but we swapped the springs over, CCT's Done, carbs swapped as well.
M.Le Drooper seems to have been owned at some stage by a gorilla who lived by the sea with a mind to over tighten every bolt & screw in sight but not bother with any cleaning ... Also seems that at some stage either the engine has been out or has been changed as the mounting bolts are a bit askew & show signs of abuse... 8O
Thanks again for all your help Carl your a star Sir...Enjoy the party tomorrow, don't eat to much jelly... :lol:
Gazfirestormowner
Mmmmm jelly
seb421
Post by seb421 »
Fitted new HEL Braided Front Brake lines to the 954 (black with blue banjos) got them a while ago but only just fitted the front ones
Its now got HEL Lines front and back and Brembo pads with a brembo rear disc, Dad is very impressed with them :)
bigtwinthing
Post by bigtwinthing »
Removed both front wheels, calapers ,discs and Bearings etc,,ready for painting next week. Anybody know where i get get new brake caliper bolts from please?
regards Paul. :D
