Airbox modding
Airbox modding
Now that's done I just need to make up the other filter spacer
Re: Airbox modding
lloydiecbr wrote: Now that's done I just need to make up the other filter spacer
And clean your shoes.
Nice job :thumbup:
Re: Airbox modding
:lol: :lol:
that only happens once a year when i get new ones :lol:
Airbox modding
ImageImageImageImageImageI had I little clearance problem on the rear carb
So I had to redo that corner
The filters I made till I buy new ones next week
Gutted .
Re: Airbox modding
Above the air filter?
Why make the upper, non-sealed part bigger?
Surely it's the section UNDER the filter that needs to be bigger.....
What airbox lid screws did you use? I just went through a jar of old self-tappers temporarily, but will sort a better/tidier solution next time I go to the fixings supplier.
Re: Airbox modding
tony.mon wrote:Above the air filter?
i know i just been reading you old post and i will relocate the spacre under the filter :oops:
ive not got round to self tappers yet b&q next week and i will need some longer tank bolts for the front :lol:
Re: Airbox modding
I suppose it's worth trying it above AND below the filter, just in case it works better above. But I fitted the spacer (10mm in my case) below the filter.
I think I'll have to slightly relieve the aluminium frame web that goes across the front of the snorkel. It compresses the snorkel and will restrict airflow a little. Head castings look thoroughly strong enough; a mm or two in the snorkel area won't make a difference.
Airbox modding
I've just undone all that welding and cleans parts up.
Refitted the spacer under the filter
And found some m5x35 s/s bolts and they work good for fitting the air box halfs together ImageImage
masterdave
Re: Airbox modding
Post by masterdave »
Where did you get the bolts from?
is the spacer just a butchered air filter or a butcherd air box? i have both of these sitting around but was unsure what bit to use to get a good seal? im planning on putting a spacer below the filter
Re: Airbox modding
masterdave wrote:Where did you get the bolts from?
i have fitted the spacer below the filter now .
the bolts are m5x35 s/s (ebay).
the spacer is a butchered air filter and a butchered air box lid .
i cut the filter as tony did and also the lid .
but i removed the lower/ outer lip on the k&n filter
this made the filter sit just inside the spacer and made a good seal
masterdave
Re: Airbox modding
wicked, this will give me something to do tomorrow, im going to start off with just cutting up the filter and finding some longer screws, my dad has way too many spare screws lying around in the shed. without any jetting or setup mods i doubt ill notice any difference with just the spacer in, im thinking about going changing my stacks to long ones at the same time as im currently running shorties
Airbox modding
Test road it with the fully modified box .
Feels good all over :-)
Dyno time next month .
Re: Airbox modding
Sorted the cylinder head breathers today .
Comments and criticisms welcome .
Re: Airbox modding
Looking good mate, but I'm not to keen on the placement of the breather bottle. It's gonna limit your access to the idle adjustment. Couldn't you put it on the other side of the carbs or up front by the snorkel somewhere. And wrap those garden hoses up in black tape. :) Those RC carb filters you listed will be perfect when you get them for the the diaphram air breathers. :thumbup:
Have you thought about what you are going to do with the extra gap around the tank your creating by raising it. You could put a VFR tank on and make some fibreglass infills for the gaps. Do a bit of bodywork tank extensions a bit like the John Brittan rep, sort off a skirt around the tank.
Good work. :thumbup:
Re: Airbox modding
cybercarl wrote:Looking good mate, but I'm not to keen on the placement of the breather bottle. It's gonna limit your access to the idle adjustment. Couldn't you put it on the other side of the carbs or up front by the snorkel somewhere. And wrap those garden hoses up in black tape. :) Those RC carb filters you listed will be perfect when you get them for the the diaphram air breathers. :thumbup:
i put the bottle their because when i find a suitable oil filler breather connector .
to fit on the clutch case it will run striate up into a + connector .
left and right cam cover breathers.
and bottom clutch cover breather.
top little pod filter .
this will mean i can do away with the bottle altogether.
and any oil that makes it into the breathers will go back into the clutch cover .
the gap around the tank isn't that noticeable to be honest unless you look for it so im not to bothered about it yet.
as for the green garden hose lol the bike will be green soon :D
