How would you describe the song of a dying CCT?
Re: How would you describe the song of a dying CCT?
Your front cct is going to pop out and punch you in the face on your way to Ali's.
Sent from my GT-19505 using Telekinesis
Virt
Post by Virt »
Jamoi wrote:Your front cct is going to pop out and punch you in the face on your way to Ali's.
Is it that big that it only requires a semi to do that? I require a full-on usually to even get near my face :/
7moore7
Post by 7moore7 »
mattycoops43 wrote:We all know VTR CCT's have catastrophic failure, but can I point out that on many other bikes, the first sign of a cct going is a rattly chain caused by the spring going weak. this CAN happen on a storm, in fact when I got my storm it had an original cct that was doing exactly that. Changed to manuals and all been fine since.
Just pointing out it is not a fail or be perfect scenario, they can go through their normal lifespan and then weaken off.
My understanding is that in most cases on I4 bikes, the CCT is a working or fail scenario as well. What is actually happening on those bikes is the CCT has failed (like on the VTR) but instead of one CCT for two cylinders, they have one CCT for 4 cylinders. What this means is that the cam chain has much more consistent and regulated "tugs" on it as each cylinder fires and there is less of a slack period so it is much, much harder for it to skip over the gears. On the VTR there is an uneven firing order from the v-twin as well as half as many cylinders, causing long pauses of slack in the chains. This means it is much easier to skip over the cam gears. So the rattling on an I4 bike is indeed a completely failed CCT (not just a warning) but because of the design of the motor it is not catastrophic.
In theory if you were lucky the broken spring would back out slowly and you might have a few minutes or days of warning, but in most cases I would guess the "warning noise" is some other noise coming from the bike.
I could be completely off on this, but from reading all of the different failure cases, this seems to be the best explanation for me.
Manual CCT's will not fail. They can be installed incorrectly (backing back out or timing issues), but I don't count this as a failure. Auto CCT's can back out as well if you don't tighten the two bolts enough. The rear wheel can come loose if you don't tighten it down, etc...
chric
Post by chric »
Let them go bang ill buy your fairing and tank then :wink:
Virt
Post by Virt »
chric wrote:Let them go bang ill buy your fairing and tank then :wink:
Even if this problem is the CCT's going, and they break tonight on the way to Al's I'm not selling anything. This bike will simply just need fixing before I use it again. I fell in love, truly, on the trackday and even restricted it's more than I hoped for (I had low expectations in fairness). You'd have to make a REALLY good offer. Sort of around the SP-1/2 price range :wink: :lol:
mattycoops43
Post by mattycoops43 »
er... no.
I have had bikes with a rattly chain, taken the cct out and it looks perfect, all working properly. changed for a new one and it cures the rattle. can only be a weak spring not strong enough to push to the next ratchet.
7moore7
Post by 7moore7 »
7moore7 wrote:
mattycoops43 wrote: I could be completely off on this, but from reading all of the different failure cases, this seems to be the best explanation for me.
I'll take your anecdotal evidence into account as I continually build my story about how the world works!
Still wouldn't chance waiting for a loose or dying noise, though... and I have a hard time believing that any decent quality spring steel will lose it's springiness over time...
ging500
Post by ging500 »
The cct spring snaps!
mattycoops43
ging500 wrote:The cct spring snaps!
yes yes yes, no point having an argument about it. I know the spring snaps, I am just saying it is physically possible for them to also weaken with time, if you maybe happened to have one that didn't go and it got to be high mileage. Also certainly not saying it doesn't need changing.
lumpyv
Post by lumpyv »
i guess its just down to metal fatigue?
if you could be bothered to take them out , take them apart then pop down to an aerospace lab and get them x-rayed you could probably have a more informed guess at when they are going to fail.
that seems quite a bit of trouble though.
quick trip to witham with my 35 quid and all my anxieties were gone . :thumbup:
Done :thumbup:
AMCQ46 wrote:Done :thumbup:
You mean the "Twilight cct saga" is finally over??
:thumbup: didn't take long
leevtr
Post by leevtr »
Good job mate. Saved the young'un some grief. What was the cutting out issue ?
Cutting out was because it was black and the engine just wanted to go slowly... Put some. Yellow tape on it and it is running fine now :D
