Page 471 of 1529
Posted: Tue Oct 01, 2013 6:48 pm
by seb421
lloydie wrote:hope you used red rubber grease on the seals.
it must off been the first time they have been off the bike .
GSXR manuel said this
CALIPER REASSEMBLY
Reassemble the caliper in the reverse order of disassembly. Pay
attention to the following points:
• Clean the caliper bores and pistons with specified brake fluid,
especially the dust seal grooves and piston seal grooves.
Specification and classification: DOT 4
* Clean the caliper components with fresh brake fluid
before reassembly. Never use cleaning solvent or
gasoline to clean them.
* Do not wipe the brake fluid off after cleaning the
components.
* When cleaning the components, use the specified
brake fluid. Never use different types of fluid or
cleaning solvent such as gasoline, kerosine or oth-
ers.
* Replace the piston seals and dust seals with the new
ones when reassembly. Apply the brake fluid to both
seals when installing them.
I normally coat seals in Vaseline but as it said brake fluid that's all i used this time
Posted: Tue Oct 01, 2013 6:49 pm
by agentpineapple
Posted: Tue Oct 01, 2013 6:59 pm
by lloydie
seb421 wrote:lloydie wrote:hope you used red rubber grease on the seals.
CALIPER REASSEMBLY
components.
ers.
Manuals
you should be fine
Posted: Tue Oct 01, 2013 7:13 pm
by 8541Hawk
While using red grease does work the best thing to use when reassembling brake components is this:
http://www.summitracing.com/parts/agb-baf12
Posted: Thu Oct 03, 2013 4:07 pm
by MacV2
MacV2 wrote:tony.mon wrote:I resurrected one of these a couple of years ago. Fuel pump was the issue there.
Pull the feed pipe off and switch on ignition, there should be a healthy flow, not a gravity-fed dribble.
Don't buy a Honda one, they're stupid money, any small petrol car one will do, as long as it's small enough.
I'll try that...
I tried that...Fuel pumps pumping fine...Sooooo it's not that.
It has an alarm fitted which seems to work OK but I have a feeling it's not got a spark which may be down to the immobiliser.
Next job, whip a plug out & test for spark...
Posted: Thu Oct 03, 2013 5:37 pm
by agentpineapple
Posted: Thu Oct 03, 2013 6:39 pm
by leevtr
Looks alright does that mate.
Posted: Thu Oct 03, 2013 6:47 pm
by lloydie
Do be carful now you have a full power black one as even with you on it 300mph is possible :-)
Posted: Thu Oct 03, 2013 7:00 pm
by koko
that looks very good.apart from the photo angle
Posted: Thu Oct 03, 2013 7:02 pm
by AMCQ46
Nice for a black one
Posted: Thu Oct 03, 2013 7:04 pm
by agentpineapple
koko wrote:that looks very good.apart from the photo angle
OI!!!!
they don't call me david bailey for nothing, in truth they never call me david bailey...
the fuel tanks come up a treat, after removing a nasty batman tankpad using a heat gun, I clay barred it, t-cut and waxed it.......top job...
whats just happened, when I posted the photos they were the right way round, now they're the wrong way round, how strange....
Posted: Thu Oct 03, 2013 7:06 pm
by VTRDark
Was you drunk when you took them pics. Sober them up in Photobucket editor.
Posted: Thu Oct 03, 2013 7:45 pm
by agentpineapple
cybercarl wrote:Was you drunk when you took them pics. Sober them up in Photobucket editor.
I did that before posting them on the forum....
Posted: Thu Oct 03, 2013 7:47 pm
by lloydie
So what's Carl doing to this one ?
Posted: Thu Oct 03, 2013 7:50 pm
by agentpineapple
lloydie wrote:So what's Carl doing to this one ?
nothing just yet mate, its a winter hack after all......
