bmw hotrod project "schnell Brutus"
wheel time
Paint the wheels red with white wall tyres
6
38%
Leave wheels alone
0
No votes
Get the dam thing done
10
63%
Total votes: 16
Re: bmw hotrod project "schnell Brutus"
i got the my tank back from my mate who soda blasted it for me
I have never heard of soda blasting before. I expect that is a lightweight version of sandblasting is it or is it a coating? :confused That tank looks so big compared to the Storm, nice!
O and i got a new helmet
What no teeth or big grin. :roll:
thumperslaw
Post by thumperslaw »
Sodablasting is a process in which sodium bicarbonate is applied against a surface using compressed air. An early use was to restore the Statue of Liberty in the late 1980s.[1]
Sodablasting is a non-destructive method for many applications in cleaning, paint stripping, automotive restoration, industrial equipment maintenance, rust removal, graffiti removal, molecular steel passivation against rust, oil removal by saponification and translocation, masonry cleaning and restoration, soot remediation, boat hull cleaning and for food processing facilities and equipment.
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
Thanks for the explanation. So if it's non destructive, to me, that is superior to sandblasting.
turbo_billy
Post by turbo_billy »
And if you wash the parts in warm water afterwards any soda "grit" that is "hiding" dissolves so no fear of anything being left in oilways etc. :thumbup:
thumperslaw
Soda good for alloy stuff unlike sand which is better for steel
K100 "flying brick"
thumperslaw
Kinda pulled the BMW out of the cover Wednesday.
Fitted the stacks to (for show )
Think it looks mean :biggrin
Had to make some steel inserts from old car exhaust
The plate is bolted to the air box which will be sprayed black
K100 "flying brick"
That looks mean. Like a spitfire engine in your bike. :thumbup: Have the stacks got a mesh filter inside of them?
thumperslaw
Kinda look am going for
Old flat ford style
They will have black mesh inside and going to dull the stacks to
K100 "flying brick"
make sure when you go for a piss in a layby you turn the engine off else something may get sucked in 8O
looks mean tho well done
thumperslaw
Sounds stupid but they are for looks only
It's really hard getting around the air flow meter and making it run right
K100 "flying brick"
CB_Phil
Post by CB_Phil »
Really like the look of the bell mouths, shes turning out to be one of the very few BMs I actually like :shifty:
Maybe I Don't Like Your Bike Either!
thumperslaw
Look even better when i get the exhaust done tho
K100 "flying brick"
thumperslaw
Re-thinking the rear sub frame at the moment (i had what i wanted in my head) but this would not work.
Stupid me did not think about wheel movement,tyre size etc
So i've got to re-do it all again :whatever :whatever
All i need now is to find a pipe bender and some tubing
I want this
:biggrin :biggrin :biggrin :biggrin :biggrin :biggrin :biggrin :biggrin :biggrin :biggrin
K100 "flying brick"
thumperslaw
Or this :eek2 :eek2 :eek2 :eek2
K100 "flying brick"
thumperslaw wrote:Re-thinking the rear sub frame at the moment (i had what i wanted in my head) but this would not work.
I want this
Yeah, but you wouldn't get all those lovely little sections welded neatly together, with blueing and golden heat hues rainbowing off the surface....
Mind you, you wouldn't if I'd welded it, either.
You'd get spatter, globs, uneven surfaces and burn holes.........
