Virt
Post by Virt »
Rip them out completely, it's not so quiet after that :lol:
leevtr wrote:
lloydie wrote:
leevtr wrote:Now its too fcukin quiet !!! May have a re think on the Remus's.
I change my friggin mind like I change my pants, once a fortnight :rolleyes4: :wtf:
did you do a full bafflectomy ?
Nope, 8 holes in each
take them out and it sounds nice and deep but without being ott
Mav617
Post by Mav617 »
I finally got round to drilling out the seized bolt in the swing-arm so I can now tap it and fit the hugger. Also put my discs on the six-spoke front and had the tyres swapped over. New p-clips for the new braided hoses on the front and new screen (Powerbronze DB) on the fairing, new front sprocket on - seemed to get a lot done today albeit they were lots of easy jobs.
Now where's the corkscrew? :beer: :beer:
Mav617 wrote:I finally got round to drilling out the seized bolt in the swing-arm so I can now tap it and fit the hugger. Also put my discs on the six-spoke front and had the tyres swapped over. New p-clips for the new braided hoses on the front and new screen (Powerbronze DB) on the fairing, new front sprocket on - seemed to get a lot done today albeit they were lots of easy jobs.
It's in Laguna Seca.
I stuck some velcro on the new(ish) carbon fibre dash, so I could attach the clock and frost warning display.
And ordered the headstock gimbal mount for the waterproof phone/satnav.
Virt and I removed his pair system buy fitting older cam covers and blocking off the two pipes ,one to the air box and one to the pair gizmo .
Fitted my bafflectomy'd standard exhausts and all is good :-)
Virt is coming on with his ability to turn spanners about time to :lol:
And thanks to Virt I'm getting pissed now :-)
Virt
Post by Virt »
lloydie wrote:Virt and I removed his pair system buy fitting older cam covers and blocking off the two pipes ,one to the air box and one to the pair gizmo .
Lefty tighty, Right loosey :wink: Felt bad that your son seemed to grab the concept better than I did, ah to be young again :lol:
Thanks for the help, and have fun with the drinking :thumbup:
Yep and he's only 9 !! Ha ha
Virt
Post by Virt »
So am I though!! :lol:
Nine....
...teen :lol:
Moocher
Post by Moocher »
Re-assembled Suspension linkage.
Pressed new needle roller bearing, attached chain runner, fitted Swing Arm, Installed rear wheel and refitted brake.
Fitted taper roller head race, re-fitted yokes forks front wheel and brakes.
Unhooked strapping from roof beam and removed wood blocking and jack.
Nothing is torqued up yet as I am still fumbling around with my first VTR re-assembly and I'm bound to have missed something and it'll all probably have to come off again so I can put things right. :confused
Nice day in the garage listening to radio four.
Oh oh also removed virts seat brackets you know the pointless ones that stop you from removing the seat without having a masters degree in nuclear fusion !
Did you adjust your chain then. :plainsmile
No his hair !! Well he needed to after using some suspect brill cream !!
Also changed clutch fluid and lubed his lever !
Mav617
Post by Mav617 »
Oooh, bet he loved that!!
Virt
Post by Virt »
It was a bit stiff beforehand!
Virt wrote:It was a bit stiff beforehand!
If you say so personally I thought it was a little bent !
