leevtr
Post by leevtr »
Today I made it noisy again :roll:
leevtr wrote:Today I made it noisy again :roll:
Did you go fully ?
And if you did how do you like it ?
leevtr
Post by leevtr »
Did you go fully ?
Nope. Put the others back on, but set them up so I can still use the original indi's. Fcuk me I'll make my mind up one day !!
leevtr wrote:
Did you go fully ?
No don't do that it's fun swing your anguish trying to find the right match :-)
GreenEyedGecko
Post by GreenEyedGecko »
Got all the crud off the pistons, hopefully that should stop them binding. Just need to put it back together properly............
mattycoops43
Post by mattycoops43 »
GreenEyedGecko wrote:Got all the crud off the pistons, hopefully that should stop them binding. Just need to put it back together properly............
Did you take the seals out and clean them?
GreenEyedGecko
Hi Matty, I ordered some new seals. They were expensive but I might have damaged the old ones getting them out. Messing about with the brakes is a bit nerve wrecking!!
mattycoops43
Cool, I only asked because you made no mention, I thought you might have popped the pistons out to clean and left the seals in place.
I am more impressed that you did a brake caliper refurb on the coffee table in the living room! are you single? :lol:
GreenEyedGecko
But its really cold in the garage, where else am I to do this? Not the kitchen, surely?!? That's crazy talk.
jonjonsocal
Post by jonjonsocal »
Took the cheap HID kit out of the bike and returned it to stock with a super bright light bulb.. I can see much better at night now.. .. Im looking for a good two way alarm for my hawk.. Any recommendations.. ? Thanks..
JON
02 VTR1000f Red
mattycoops43
I started some preliminary unbolting, took off the seat unit, tank and fairing in preparation for fitting a replacement loom, I also soldered a rear light plug on the new loom which was the only bit missing.
Just waiting for my reg/rec to turn up from the states then I'll do the whole job in one go.
Started to fit the cable clutch conversion to see what other parts I need and I need some more :ball kick:
leevtr
Post by leevtr »
Think I've bent my sidestand !!
Pulled up at Barts Hospital today, and as I pulled the key out I didnt have hold of it properly and it slipped between the tank & frame rail, dissapeared down under the airbox !!!!!!
Needless to say I had the bugger in all sorts of odd angles trying to shake the key into falling through onto the ground. Got it in the end, but what a fcukin' palava !!
Sorry to laugh at your misfortune Lee, but that did make me chuckle :lol::lol::lol::lol:
