oh yes you are correct. it is an addictive noise that sounds like it could suck the hedges in from the road side............ especially winding on the throttle mid rangecybercarl wrote:. I swear there is more intake noise with the Dr Honda's compared to two standard long stacks.
Well it aint going to fall off if that's what you meanis your exhaust 100% as good as it's going to get?
How far did you strip it back? I've ordered some upper/lower fork bushes and stuff to service my forks after our chat on wobbly legslloydie wrote:Today I removed the front end to find out why if felt crap .
Rebuilt it and test road it feels better
Jamie
Dropped the forks .
Reduced the preload .
Set head bearing and it did feel a lot better not great as it still needs tweeking .
Tomorrow I'm doing the rear ! Don't know why it felt so crap after the rebuild .
Good man make sure you give them a good clean oh and I always soak the bushes in oil over night !Jamoi wrote:How far did you strip it back? I've ordered some upper/lower fork bushes and stuff to service my forks after our chat on wobbly legslloydie wrote:Today I removed the front end to find out why if felt crap .
Don't know why I've always done it ?
Sweet, thanks I've never taken forks apart before but the guide is clear enough even for a doofus like melloydie wrote:Good man make sure you give them a good clean oh and I always soak the bushes in oil over night !
Jamie
Today I made a start on reaching the end goal for my bike. Hopefully get the ball rolling properly on Saturday/Sunday. Can't say much more as I'm not 100% sure how it will all work out in the end but I shall update when I have more to update on. Feeling excited
Ckennedy wrote:Today I made a start on reaching the end goal for my bike. Hopefully get the ball rolling properly on Saturday/Sunday. Can't say much more as I'm not 100% sure how it will all work out in the end but I shall update when I have more to update on. Feeling excited
chris, did carl give you some of his herb tea last weekend? you are talking in riddles.
I will update when I more to update on
I have a sneaking suspicion... winkywinky elbow elbow
Jamie
Yep I some how had some stiction in the forks so they weren't working as they should .Virt wrote:Glad I wasn't alone with that thought processlloydie wrote:
And loose head bearings didn't help !
Just need to set the damper rebound now as it still feels like it's to hard and not riding through the bumps more like it's riding over them
Don't worry he'll change his mind in 5 minutes and again in 10-20-40 minutes !!!Jamoi wrote:![]()
AMCQ46 wrote:Ckennedy wrote:Today I made a start on reaching the end goal for my bike. Hopefully get the ball rolling properly on Saturday/Sunday. Can't say much more as I'm not 100% sure how it will all work out in the end but I shall update when I have more to update on. Feeling excited
Yes but I think I over did it. First time and all
Becides it keeps you all guessing.
You ain't kidding !!!! Next time I'm going to kick you in the nuts :-)Ckennedy wrote:AMCQ46 wrote:Ckennedy wrote:Today I made a start on reaching the end goal for my bike. Hopefully get the ball rolling properly on Saturday/Sunday. Can't say much more as I'm not 100% sure how it will all work out in the end but I shall update when I have more to update on. Feeling excited
Yes but I think I over did it. First time and all![]()
Right… Found why the the bulb wouldn't work with the ceramic H4 bulb holder I'd added onto my Eastern Beaver relay kit - Spot the deliberate mistake discovered by my mate Steve who knows how to wield the continuity function on a multimeter...
Wicky wrote:Sunny but frustrating day fitting Eastern beaver relay kit - sodden thing didn't work. Should be a plug&play item but bulb wouldn't light up despite relays clicking. Used multimeter to find diddly-squat output from bulb connectorLittle option but to unravel it and revert back to standard. While things were apart tried to fit 8mm quick release fuel connectors - no way with the slop in the 10mm ID hose would they have sealed securely
So only positive is some hidden parts are a little cleaner and nuts & bolts recopper-greasesed for when I can be arsed to go back in again...
