last time I jacked it up I used the trolley jack then promptly tripped over the handle and nearly knocked it all over, so the scissor jack is the best option, I'm even thinking of welding on a little saddle affair to fit the shape of the sump to give it more stability.cybercarl wrote:Argh the good old scissor jack....no garage should be without one.getting the front end off the floor and the bike secured involved a scissor jack![]()
Don't know if you have read it but don't torque the tapered bearings up the same as standard.
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=15681
Yes I know about the different tightening procedure for the taper bearings
