CCT replacement/ alternator bungs
Murv
Re: CCT replacement/ alternator bungs
Post by Murv »
Mine turned up today :thumbup:
It's surprising (and probably a bit sad) how excited I can get over a couple of lumps of metal, but these are beautiful :biggrin
Murv wrote:Mine turned up today :thumbup:
Agreed.
Almost too good to waste on a thirteen-year old rattly hack like mine........
TonyW650
Post by TonyW650 »
Mine turned up today.
Very nice, well impressed
cheers
Xenocide
Post by Xenocide »
These are beautiful. One question though...
How the hell do you make the allen headed holes? Always wondered that.
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
gl_s_r
Post by gl_s_r »
I broach them with a hexagon headed tool.... :shh:
Xenocide
Post by Xenocide »
I don't know what that means but it sounds bloody impressive.
'94 KTM LC4 400e
Xenocide
Post by Xenocide »
Woahhhhhhhhhhh
'94 KTM LC4 400e
gl_s_r
Post by gl_s_r »
bit antiquated that one...
This is more like it. http://www.youtube.com/watch?v=tg0q2kgIVxo
you made us a work of art :thumbup:
gl_s_r wrote:bit antiquated that one...
I can't get my head round that one. If it's spinning it then cuts at the highest point of the bit, so makes a circle. :confused
How do you fancy having a go at making some caps for the swingarm where it meats the frame?
gl_s_r
Post by gl_s_r »
It revolves at the same speed of the material you are broaching.
The broach has a small angular offset to it at around 1 or 2 degrees so it actually pointing off centre. Then when it hits the part it synchronises speed wise and in effect is actually stationary. The angular offset I mentioned earlier then moves in a rotary fashion and it effectively forms the hexagon by gently beating the material, it doesn't really cut a shape but rather shears it by "pecking" the shape.
You'll see the chamfer at the front of the hex and the hole being deeper than the hex I put in is a necessity to broaching.
I have read that back and it does sound more complicated that what it is... I'll see if I can find another link to make it more "sensical"?
In this link http://www.youtube.com/watch?v=BhvNU2E_x_Y you can see the broach stop on contact and then wobble to form the hex in the plastic..
gl_s_r
Post by gl_s_r »
Did you mean some caps to replace the plastic ones in the footpegs?
seb421
Post by seb421 »
gl_s_r wrote:Did you mean some caps to replace the plastic ones in the footpegs?
that would look nice!
bloody hell, that broaching is clever, I think it makes sense to me now. So the wobble effect is like having a cam so you get the high point and low point as it spins. That's my lesson learned for today. :)
Exactly :thumbup: the biggest problem with the plastic ones are that they wear on the edges from a screwdriver being used to pry them off when using an Abba stand, and they are just tacky looking.
Xenocide
Post by Xenocide »
I just wanted to say thank you very much to gl_s_r, my bungs turned up today and they're a work of art! I'm in love. Phoawrrrr
'94 KTM LC4 400e
